+ Reply to Thread
Results 1 to 5 of 5
Thread: LM3914 Problems
  1. #1
    tvsound Newbie
    Join Date
    Mar 2009
    Posts
    11
    Default LM3914 Problems
    I am trying to build a circuit that has 3 cascading LM3914 chips driving 30 leds in dot mode and am encountering the following problem...
    When the signal input is above the V-Hi reference level the top led of each chip stays on.
    So...even though the "bargraph" does what I want...ie, as the signal voltage drops the leds go from "top" (led 1) to "bottom" (led 30) when the signal voltage is at it's highest (in this instance 1.25V) as well as led No.1 being on (which I want) led No.11 & LED No. 21 are also on.
    I can see that if I was running this in "bar" mode it wouldn't be a problem but I really need to run this in "dot" mode.
    Any Suggestions???...I am currently copying the circuit out of the NS datasheet onto a breadboard and am fairly sure I am not making any mistakes.
    Please feel free to enlighten me...and as I am very dim and a newbie at electronics please feel free to make your answers as basic as you wish!!!!...and if you want to include a circuit diagram that would be great!!!
    Kind Regards
    TVSound:
  2. #2
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    Additional wiring is required for the dot mode to work properly while the chip is cascaded, it's fully covered in the PDF data file how you need to hook them up. It's relativly simple, it requires as 10 or 20k resistor and a few lines from each chip to be hooked up in a certain way.
    straight answer, har har."
  3. #3
    tvsound Newbie
    Join Date
    Mar 2009
    Posts
    11
    Yep...I agree...and I'm sure I'm doing it right!!!!
  4. #4
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,879
    Why are there two threads about this one topic?
    I answered the other thread.
  5. #5
    tvsound Newbie
    Join Date
    Mar 2009
    Posts
    11
    You're a very helpful fellow.
    TVS
+ Reply to Thread
  1. LM3914.. another Help!
    By minnie_m0use in forum Electronic Projects Design/Ideas/Reviews
    Latest: 9th March 2009, 04:02 PM
  2. LM3914 used for ammeter
    By rapid in forum General Electronics Chat
    Latest: 6th November 2008, 09:41 PM
  3. Linear Vs. Log LM3914/5
    By mike11298 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 4th February 2008, 06:46 AM
  4. Help with LM3914
    By Pfrogs in forum Electronic Projects Design/Ideas/Reviews
    Latest: 29th August 2007, 12:40 AM
  5. LM3914
    By Ryan Harding in forum Datasheet/Parts Requests
    Latest: 21st January 2005, 06:07 AM
Tags for this Thread
