| | #16 |
Wait - I'm Duffy himself, how can you be Duffy yourself?
| | #17 |
11 is the load pin so when the dip switches connected to pins 9,10,1,15 are preset then the value gets loaded into the 74192 when pin 11 is grounded. if building this I and don't need the programable inputs then connect a 1k resistor to pullup pin 11. pin 4 is the down pin. pin 5 is the up pin. I see your post refering to a variable voltage. did you even look at the 15 step variable voltage circuit? Electronics for You-Circuit Lab- Free and tested circuit diagrams-15-Step Digital Power Supply this circuit has BCD outputs!! must be young high school kids or ?? that want somethig easy. how much easier than the link I gave you?? its exactly what you want as per your description just add the 7447 and the 7 segment display or better yet the 4511 it has 2 latch/decoder/drivers per chip | |
| | #18 |
Thanks for the answer, but i went ahead with my original design and solved the problem by making the circuit in a program called Tina 8.0. But now i'm a bit lost on how to connect the DA converters. I've connected them like this so far: ![]() And now i don't know how to connect the 4 remaining pins on each of them. The analogue output (i assume this is the one called A) from each of the DAC's, has to be connected to the OP AMP to compare them. When the bottom DAC gives a higher output than the upper, the lamp after the DAC has to light up. edit. oops, posted wrong picture Last edited by DuffyHimself; 13th April 2009 at 03:57 PM. | |
| 7segment, adjustable, counter, digit |
| 2 digit 7 segment display.. | overmind | Micro Controllers | 12 | 17th January 2008 04:34 AM |
| Two Digit, 7 Segment Display Counter For A Hand Steady Game | stevo2005 | Electronic Projects Design/Ideas/Reviews | 3 | 11th January 2007 11:07 PM |
| 2 digit 7 segment display | soryo | General Electronics Chat | 10 | 14th August 2006 05:17 PM |
| 4-digit seven segment display | s2301931 | Electronic Projects Design/Ideas/Reviews | 2 | 20th April 2006 07:57 AM |
| Single digit 7 segment VF displays | Eclipsed | General Electronics Chat | 6 | 12th July 2005 04:57 AM |
