+ Reply to Thread
Page 4 of 4
First 1 2 3 4
Results 46 to 56 of 56
Thread: Simple RPM Switch
  1. #46
    thekyguy11 Newbie
    Join Date
    Jan 2008
    Posts
    104
    Quote Originally Posted by Pommie View Post
    There is something not right here. Nothing works with a 100mV signal and so I suspect something else is wrong. When you look at the original signal do you have the existing tachometer connected? I ask as the sensor could be a simple (transistor) switch to ground that requires a pullup in order to work.
    To answer your question, no, a transistor will not be switched on by 100mV. It needs several times that voltage.
    Ah, I completely missed what you said about using the a pull-up resistor in order to work. I get the idea, not sure how to apply it though. You mean one of these setups?
    or
    If so, how do i find out if this is the case?
  2. #47
    Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent
    Join Date
    Mar 2005
    Location
    Brisbane Australia
    Posts
    6,792
    Quote Originally Posted by thekyguy11 View Post
    Connect your scope from 12V to the signal wire and see what you get. Also, while your there, have another look at what you get between 0V and the signal line.
    thekyguy11 Newbie
    Join Date
    Jan 2008
    Posts
    104
    sounds good, Ill do that and check back.
  4. #49
    thekyguy11 Newbie
    Join Date
    Jan 2008
    Posts
    104
    checked the signal wire again. It turns out I am an idiot after all! I had the leads for the scope in the wrong spot. they were in the spot for the meter function, so the 100 mv it was reading was just being picked up without a lead in the scope "input". After connecting it correctly, I saw the pulses actually go from 0v to battery voltage (~12V-14V).
  5. #50
    snowkabous Newbie
    Join Date
    Mar 2009
    Posts
    4
    Hi, you have a very interesting topic and i would like to build the same type of project. Can you help me with this please? I am new here and also do not have the know hows of it. Thanks
  6. #51
    thekyguy11 Newbie
    Join Date
    Jan 2008
    Posts
    104
    Well, to be honest, I am kind of at a stand still until I find some time to do some testing on the RPM input. My wife and I are searching for our first house, so this project had to take the back burner.
  7. #52
    snowkabous Newbie
    Join Date
    Mar 2009
    Posts
    4
    Default rpm switch
    Cool no problem i do understand, thanx for your time to reply
  8. #53
    snowkabous Newbie
    Join Date
    Mar 2009
    Posts
    4
    Lightbulb RPM switch
    Howzit buddy, i have found what we both are looking for, it just need a small change in parts. Send me your email then i can mail you the diagram with list of parts and assembly details. Chiao
  9. #54
    KMoffett Excellent KMoffett Excellent KMoffett Excellent KMoffett Excellent KMoffett Excellent
    Join Date
    Oct 2007
    Location
    Minneapolis MN USA
    Posts
    1,384
    Quote Originally Posted by snowkabous View Post
    How about posting it here so everyone benefits.
    ken
  10. #55
    thekyguy11 Newbie
    Join Date
    Jan 2008
    Posts
    104
    yea, you should post it up for sure!
  11. #56
    snowkabous Newbie
    Join Date
    Mar 2009
    Posts
    4
    Quote Originally Posted by KMoffett View Post
    ken
    Hi, i cant copy and paste it, send me your email to rautenbach9@gmail.com then i will mail it to you
+ Reply to Thread
Page 4 of 4
First 1 2 3 4
  1. simple wireless switch
    By jacob.zurasky in forum Electronic Projects Design/Ideas/Reviews
    Latest: 25th February 2010, 04:36 PM
  2. Simple relay switch - but how?
    By daveguk in forum Electronic Projects Design/Ideas/Reviews
    Latest: 22nd October 2008, 12:06 AM
  3. Simple remote switch?
    By wsemajb in forum Robotics Chat
    Latest: 19th October 2008, 08:51 AM
  4. simple switch
    By BrianO in forum General Electronics Chat
    Latest: 11th March 2004, 04:05 PM
  5. Simple IR switch
    By driver1 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 9th December 2003, 08:35 AM
Tags for this Thread
