+ Reply to Thread
Results 1 to 9 of 9
Thread: Uart
  1. #1
    ananth85 Newbie
    Join Date
    Jan 2009
    Posts
    36
    Default Uart
    Hello,
    Bro i am Ananth here,I need help regarding this project.I have attached together the information regarding my project. I need help regarding interfacing my UART. I am planning to use a stand alone UART chip. If I use a microcontroller with UART I will face problem in the software part as there is ADC and DAC in my project. I need to know how can a stand alone alone UART chip could be used. My supervisor has also wished that i used a stand alone UART ic to communicate.Could anyone help me on this issue.
  2. #2
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,708
    Blog Entries
    5
    A stand alone UART will still require something to control it. Ie a microcontroller.
    Bill
    Smart Kits build Smart People
  3. #3
    ananth85 Newbie
    Join Date
    Jan 2009
    Posts
    36
    Default HI
    Hmm, i also need both UART to communicate using RF.No way of making a UART to communicate by itself without a microcontroller. Once the data is out from encryption sending it to the the UART Tx and receiving it at Rx via RF
  4. #4
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,708
    Blog Entries
    5
    How would the UART know what you expect it to do? Most modern microcontrollers have one built in.
    Bill
  5. #5
    ananth85 Newbie
    Join Date
    Jan 2009
    Posts
    36
    ok,as u c my attachment,a PIC would have a build in A/D converter in it so is it i can use the a/d coneverter and UART at the same time. The A/d is 8bit but the encryption needed to be done in 16 bit and UART only communicate in 8 bit. How to work this out
  6. #6
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,708
    Blog Entries
    5
    An 8 bit controller can do 16 bit things, it just does them 8 bits at a time. You should probably start with some simple programming before attempting a complex project.
    Bill
  7. #7
    ananth85 Newbie
    Join Date
    Jan 2009
    Posts
    36
    once the data is converted from analog to digital using my pic i need to encrypt it using X-OR or or i can make the PIC to do it before send it to the UART to transmit
  8. #8
    dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent
    Join Date
    May 2006
    Location
    Alberta, Canada
    Posts
    6,028
    THe PIC has to do it before you send it over the UART. THe UART doesn't do anything on it's own (except blindly sending whatever information has already been placed into it's memory).
  9. #9
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,788
    Quote Originally Posted by ananth85 View Post
    It's all trivial to do in the PIC, no external devices required at all.
+ Reply to Thread
  1. IR And UART
    By gramo in forum Micro Controllers
    Latest: 18th August 2009, 05:22 AM
  2. pic & UART help
    By nabil13 in forum Micro Controllers
    Latest: 16th February 2009, 01:57 AM
  3. Need UART help
    By ExtravDreams in forum General Electronics Chat
    Latest: 28th May 2008, 04:54 AM
  4. What is a UART
    By Marks256 in forum General Electronics Chat
    Latest: 19th June 2007, 01:09 AM
  5. uart
    By amenoera in forum Electronic Projects Design/Ideas/Reviews
    Latest: 17th August 2005, 05:31 PM
Tags for this Thread
