Old 23rd February 2009, 05:50 PM   #1
Default Adjustable Current Source max 10A
Hellow,
For a project I need an adjustable current source with a maximum output of 10A. This current will be used to make an electromagnet, the coil of the magnet has a resistance of 1,590 ohm, sow the maximum power will be around 16V.
I can't find any schematics of such a supply on the internet, can anybody give me some information on this?
Greetings!
drekkY is offline
Old 23rd February 2009, 08:28 PM   #2
If the resistance is 1,590 ohms, a 100v supply will pass only 0.06Amps.
To deliver 1 amp will need a 1,590 volt supply.
colin55 is online now
Old 23rd February 2009, 09:36 PM   #3
I believe the resistance is 1.59 ohms (USA notation) thus the need for 16V to get 10A.
Any standard bench power supply that will provide 10A at 16V will work. Many companies make such supplies. If you Google "10a adjustable power supply" you'll get many hits.
Carl
Curmudgeon Elektroniker
crutschow is offline
Old 24th February 2009, 09:55 AM   #4
I know it is possible to buy such a source, but it have to make my own.
The LM3886 (LM3886 - High-Performance 68W Audio Power Amplifier with Mute) can deliver a current up to 11500 mA. But I don't think the circuit mentioned on the above page meets my requirements.
Can anybody help me with an alternative circuit?
drekkY is offline
Old 9th June 2009, 04:21 PM   #5
I also need one for driving power LEDs.I found one which uses LM317 but it can can give up to 2.2 A max.So I am searching for other alternatives.
No one Dies Virgin,Because In the End Life F***s Everyone
Rikil Shah
B.Tech-2nd year,
Electronics Engineering
Sardar Vallabhbhai National Institute Of Technology,
India.
Currently working on ARM,AVR,PIC
My Official Blog:-www.rikil-svnit.co.nr
rikilshah is offline
Old 9th June 2009, 05:07 PM   #6
Use Google and look for high power led driver.....You use an external PNP power transistor to supplement the 317's current capability....See here...http://www.uoguelph.ca/~antoon/circ/ampboost.html
Eccentric millionaire financed by 'er indoors
Chippie is offline
Old 9th June 2009, 06:20 PM   #7
thanx..that is simple and cheap solution......if we can use P-MOSFET than can have more current...and can you say what is max current we can get??
Rikil Shah
B.Tech-2nd year,
India.
Old 9th June 2009, 06:55 PM   #8
Experiment........Thats what it's all about....How do you think I learnt?
Chippie is offline
Old 9th June 2009, 07:00 PM   #9
Yeah thats true...:
now can you give me some idea about this idea..
how is a constant current supply made
Rikil Shah
B.Tech-2nd year,
India.
Old 9th June 2009, 07:05 PM   #10
Look at this sim. Its a place for you to start. Note the power dissipation in the FET and in the shunt. You will have to use a LARGE heatsink.
MikeMl is offline
Old 9th June 2009, 07:20 PM   #11
I think voltage is much less...I need to drive 3 LEDs in series so I need 12 V.
and I can't understand use of two power supply...
Rikil Shah
B.Tech-2nd year,
India.
Old 9th June 2009, 08:28 PM   #12
The first ...unregulated supply is like your battery....
The second is a control supply...vary it and you vary the current...fix the voltage at some pre-determined level and the current is fixed
Chippie is offline
10a, adjustable, current, max, source
High power adjustable current regulator yngndrw Electronic Projects Design/Ideas/Reviews 32 17th June 2009 10:39 PM
0-10V adjustable power from 12V source alexchannell General Electronics Chat 17 26th January 2009 11:56 PM
Adjustable Current Output moctod Electronic Projects Design/Ideas/Reviews 8 20th February 2007 02:56 AM
adjustable current booster zhi_yi General Electronics Chat 11 4th September 2006 02:12 AM
Adjustable Constant Current Source graemec Electronic Projects Design/Ideas/Reviews 14 29th August 2006 08:46 AM
