First of all I would like to say that I am a complete electronics newbie, I literally know nothing so any advice is going to have to be simple and step by step. Here's the situation, i'm trying to design a battery powered counter that uses three seven segment displays. I'm using a very basic simulator program called crocodile clips so apologies for the quality. There are only two switches that are really important in my design. In the top left is the on/off switch, and on the right of the second seven segment is the switch that will increase the displayed value by one. However when I turn the circuit off and then on again the decoders and counters break. I believe that i may need some sort of voltage regulator, if so can somebody please show me exactly what i should do, if not any other suggestion would be welcome | |
Of course, you should regulate with the HC series, but you might try switching the high side (plus side of battery) instead of the low side, first. Maybe that's the problem. There may be ground bounce causing reverse voltage condition if you switch the circuit off then immediately on again.
here is a pic of the circuit when the problem occurs, the blanked out components are the ones which break. If I do need a voltage regulator can you show me exactly where as I just checked the program and it doesn't have one.
| | #4 | |
So the battery +V to the anode of a diode, another diode then the +V to the logic supply. Each diode will drop about 0.65V, so 2 * 0.65V = 1.3V drop, this will leave about +4.7V at the logic power pins. OK.?
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 23rd February 2009 at 09:23 AM. | ||
I have tried what you suggested and have discovered a new problem. I can lower the voltage sufficiently so that the decoders and counters do not break, however the 7 segments then turn off!
| | #6 | |
Looking at the circuit, in a 'real' circuit the 7segs would work OK. The problem is in the simulator. Try using just one diode, not two.
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 23rd February 2009 at 01:37 PM. | ||
| circuit, counter, desperate, needed |
| HELP Needed!! - 7 Segment LED counter (74LS90 TTL) | kwon | Electronic Projects Design/Ideas/Reviews | 19 | 21st October 2009 04:00 PM |
| Time delay circuit needed for counter | djreiswig | Electronic Projects Design/Ideas/Reviews | 0 | 5th September 2008 03:37 PM |
| Photo optic event counter needed | easytim | General Electronics Chat | 21 | 18th August 2008 11:19 AM |
| Desperate help needed re IRFZ34N mosfet / tip 42 | alay1 | General Electronics Chat | 15 | 8th February 2007 03:05 PM |
| LCD or LED rev counter(tacho) info needed | smokie | Electronic Projects Design/Ideas/Reviews | 1 | 2nd April 2003 08:47 AM |
