+ Reply to Thread
Page 2 of 7
First 1 2 3 4 5 6 ... Last
Results 16 to 30 of 103
Thread: Help with dynamic test load
  1. #16
    imix500 Newbie
    Join Date
    Feb 2009
    Location
    Putnam, NY
    Posts
    80
    I took the common cathode stage out and am driving the mosfet through a 1k resistor. First off the weird thing. With both pots down it draws 2.1 amps at 5v. 100mV is appearing at the 2k resistor as expected, but 22mV after it at pin3. Should that resistor be dropping that much?
    I built the multivibrator and it works great. The smallest output I can get is about 37mV and that turns the entire wave at the gate into a lower frequency wave. (terrible pic attached) If I increase the frequency, it settles down and the square wave can be seen cutting into the opamp's wave.
    Also, I played with the compensation values and didn't really see much change. I went to a max of 1uF on the added cap and to 50k on the added resistor. The wave shape stayed the same.
  2. #17
    Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,721
    That doesn't look like the 555 output. You should be seeing almost 50% duty cycle.
    The op amp doesn't have a wave, as you said. That other crap is probably from ripple on your 12V power supply, or a result of poor grounding, or something like that.
    Ron
  3. #18
    imix500 Newbie
    Join Date
    Feb 2009
    Location
    Putnam, NY
    Posts
    80
    That is at the gate of the mosfet. The wave shown in post 10 is what the output looks like without any modulation-thats what I meant by "the opamps wave". As input voltage/current draw increases, the whole waveform compresses and flattens out. When the square wave (which looks great) is added at low level, the waveform goes crazy.
    I battled with the small switcher I'm using to run the whole thing, as well as the brushless fan's emi. I added a pi filter between the fan and added filter caps at the opamp board and it helped a lot. However I'm considering using a seperate supply for the opamp as I'm not convinced psrr is not still having an affect.
    I'm using star grounding for the whole thing, but a ground problem is certainly possible.
  4. #19
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,721
    I just noticed that the reference voltage (pin 3 on the op amp) is developed from the supply under test. This is wrong! It should be developed off +12V, which should be a linear regulator, and independent from the supply under test.
    I think the best place to view the output waveform is across the sense resistor, although the gate waveform should be similar, but larger in amplitude. If you probe across the sense resistor, Make sure both probes are as close to body of the resistor as possible.
    A star ground is essential. Does this include the connection of the 510Ω resistor to the sense resistor?
    Ron
  5. #20
    imix500 Newbie
    Join Date
    Feb 2009
    Location
    Putnam, NY
    Posts
    80
    Oh, well that's a problem then. Funny, the first version of this actually used a precision 2.5v reference with the pots for the reference signal.
    Since the supply is 12v on the money and wouldn't have any headroom for a 12v reg, could I use a 9v battery or 7809 to power the opamp and provide reference voltage to the pots? The only problem I can see with a battery is if I go back to a big power module, they need a good bit of drive current. More than a 9v could supply for too long.
    Everything runs to the star ground except the fan and the power led. The 510ohm resistor literally ties directly to star gnd and pin3.
  6. #21
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,721
    Quote Originally Posted by imix500 View Post
    The only problem I can see with the 12V switcher is that it makes it difficult to view the transient response test. A little switching noise in your load should not be a problem. If you want to clean it up with a 2.5V reference, I can post a schematic if you don't have one.
    Regarding the 9V battery, the voltage may be a little low for the gate drive of the MOSFET circuit at max current. As far as the battery lifetime with the power module is concerned, the op amp short circuit current is 40mA, and can only supply about 10mA reliably. I'm not sure that is enough if the load is hundreds of amps.
    Ron
  7. #22
    imix500 Newbie
    Join Date
    Feb 2009
    Location
    Putnam, NY
    Posts
    80
    Ok, linear wall wart it is followed by regulation.
    When I get another triple darlington module (only about $20 surplus) for the largest of the three units I'm building, I'll put the common collector stage back in to get the needed current. I'll report back tonight. Thanks!
  8. #23
    OutToLunch Good OutToLunch Good OutToLunch Good
    Join Date
    Jun 2006
    Location
    North Carolina, USA
    Posts
    355
    i'm a little late to the party, but do you have a list of specifications that this load generator needs to meet? are there any load slew rate requirements?
    Also, I would suggest - unless the testing requires longer on-times - to cap the duty cycle at 10%. There's still a lot of power to dissipate, but low duty cycles should help to keep that to a minimum. The period will have to be determined by the specs of the supply - expected settling time, etc.
  9. #24
    imix500 Newbie
    Join Date
    Feb 2009
    Location
    Putnam, NY
    Posts
    80
    Hi OutToLunch,
    I'm actually building three different sizes of these. One to about 500W, one to about 1.8kW, and the third Probably to 5kW. The reason for three is location and portability. These will be used on existing supplies to periodically check general health.
    Duty cycle will mostly be short, say 15mins, but could be all day if we're torture testing. The units (except for the largest) are surprisingly compact already.
  10. #25
    imix500 Newbie
    Join Date
    Feb 2009
    Location
    Putnam, NY
    Posts
    80
    Ok, did a lot to this last night and today. Built a new psu with good regulation and better isolation from the cooling fan. Fixed reference voltage section, and replaced the 100k pot with a 1meg.
    The first pic is 6Hz across the sense resistor without compensation.
    The second is with .03uF compensation.
    Seems like that value is a good compromise, but how far should I go with capacitance here? I found that with enough, it did exactly what a large value should do- squash and flatten the square wave.
  11. #26
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,721
    Actually, it appears to be fine without compensation. I think the droop is due to either the input coupling capacitance, or having your scope AC-coupled.
    If you want to leave in the compensation, It won't hurt anything unless you decide to make the current controlled by an external pulsed voltage source.
    Ron
  12. #27
    imix500 Newbie
    Join Date
    Feb 2009
    Location
    Putnam, NY
    Posts
    80
    Well thats encouraging. I did have the scope on ac coupling. Should I try viewing it on dc?
    I can't load it up to where the other designs have failed until I get parts, but I'll report back when I do. Thanks!
  13. #28
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,721
    The problem with DC is you will probably have a small pulse waveform with a large DC offset, making the response hard to see. Try raising the frequency of your test oscillator by a factor of 10 or more, and keep the scope on AC.
    Yeah, I'm still worrying about why it died. The frequency stability will change as you add more MOSFETs, if that's what you are planning.
    Ron
  14. #29
    imix500 Newbie
    Join Date
    Feb 2009
    Location
    Putnam, NY
    Posts
    80
    Ok, I'll try raising the frequency.
    I've ordered a few of the large power modules for the units because I got them for less than a couple tubes of the mosfets and I don't have to worry about matching. Probably just need to add a big emitter resistor when I parallel a couple of them in the largest unit.
    Now that I have a clean supply and better stability at low power (which I didn't have before) I'll be interested to see what it does as well. All three designs failed when I put an old 24v 750W switcher on them. It was ok until I hit an imaginary line and it became unstable VERY fast.
  15. #30
    Join Date
    Jun 2006
    Location
    North Carolina, USA
    Posts
    355
    Raising the frequency will likely cause more heat dissipation in the pass element due to increased switching losses. I would recommend reducing the duty cycle to no more than 10%. You had mentioned your duty cycle is 15mins - i mean the duty cycle of the individual load pulses. For example - if the loading period is 1msec, the time that the load should be applied would be 100usec. You can obviously increase the period but keep the duty cycle low to reduce power loss across the pass device. This should still allow you to see how the power supply responds to the load.
+ Reply to Thread
Page 2 of 7
  1. SSR, inductive load verse resistant load
    By joshua17ss2 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 16th April 2008, 09:40 PM
  2. Dynamic Charging
    By Deezy in forum Electronic Projects Design/Ideas/Reviews
    Latest: 29th March 2008, 02:11 AM
  3. dynamic Mic replacement
    By g6ips3y in forum Datasheet/Parts Requests
    Latest: 10th January 2005, 03:30 AM
  4. Test For Inductor Motor :No-Load and Blocked Rotor Test
    By shermaine in forum General Electronics Chat
    Latest: 28th March 2004, 02:06 AM
  5. Dynamic mic connection to mic amp
    By hantto in forum General Electronics Chat
    Latest: 9th January 2004, 04:27 PM
Tags for this Thread
