12hour timer using two 555 timers.
12 Last »
  1. #1
    dottedquad dottedquad is offline
    Hello all, I'm currently working on a project that utilizes two 555 timers. The first 555 timer controls the 12 hour(I'm assuming the delay) once the 12hour has been met, trigger the second 555 timer to turn on a relay for approximately 2-3 seconds. Once the 2-3 second is met trigger the first 555 timer. That sounds simple so far except when I run into the RC circuit. I'm not sure what resister and capacitor to use for the 12hour.
    I realize I can use a kitchen timer to set the on and off times and hook that up to the 2-3 second 555 timer. I'd rather not use this approach.
    -Thanks,
    rich
  2. #2
    Menticol Menticol is offline
    I asked the same thing, 555 doesn't work for times that longer
    Camera intervalometer
    0
    Felipe
    Visit my blog cocodrilabs.wordpress.com - Electronic Projects, DIY Repairs, Device Modification and Improvement.
  3. #3
    Quote Originally Posted by Menticol View Post
    Wonderful! I apologize for double posting. I did a search for 12hour 555 timer which yielded no results. As I wasn't sure what else to search for, I posted my question.
    -Thanks
    0
  4. #4
    creakndale creakndale is offline
    You might try to locate these Exar Long Range Timer IC's on eBay for your 12 hour delay:
    XR-2240
    XR-2242
    creakndale
    0
  5. #5
    davidbear davidbear is offline
    Are you fundamentally opposed to using another chip other than the 555? I'm no expert, but I would think that you could set the first 555 to run as a multivibrator at say 0.1Hz, feed that signal into a 14-bit binary counter, and have it set off your second 555 to release a 2-3 second burst and reset the 14-bit counter.
    0
  6. #6
    KMoffett KMoffett is offline
    Maybe something like this?
    Repeating Interval Timer
    Ken
    0
  7. #7
    Quote Originally Posted by davidbear View Post
    I'm a beginner at electronics. I'm afraid that's way over my head. I'm not quite sure how that would work. Also, I'm not opposed to using another chip other than the 555. I was checking out the CMOS 4060.
    -rich
    0
  8. #8
    blueroomelectronics blueroomelectronics is offline
    Help us help you
    The 4060 will require lots of dividers to get 12Hrs. Is it going to be connected to AC (Mains)? If so you could drive the counter with a 50/60Hz signal.
    0
    Bill
    Semi retired, now just blogging
    http://colossus.dsmynas.com/
  9. #9
    Hero999 Hero999 is offline
    Don't expect great accuracy.
    Two Simple 24-Hour Timer Circuit Schematics
    0
  10. #10
    notauser notauser is offline
    Another option would be to see if you can find a dollar store digital clock or something you can rip apart and tap into..
    0
12 Last »
555 timers ch.v.v.kumar Electronic Projects Design/Ideas/Reviews 6 4th July 2011, 08:02 AM
i need tow timers,but AVR simulation "avrsim version1.11" have one timer kasser AVR 5 25th February 2007, 09:22 AM
Do u have 12hour PIC16F84A clock pasanlaksiri Microcontrollers 2 8th February 2007, 09:14 PM
555 timers jasona@wbeer Electronic Projects Design/Ideas/Reviews 4 31st August 2005, 08:37 PM
Timers ? Titanium General Electronics Chat 5 30th July 2003, 10:26 AM
Page Time: 0.05062 seconds      Memory: 7,551 KB      Queries: 16      Templates: 0
