+ Reply to Thread
Results 1 to 6 of 6
Thread: how to prevent negative voltage to enter into IC
  1. #1
    ponsakthi Newbie
    Join Date
    Dec 2008
    Posts
    29
    Default how to prevent negative voltage to enter into IC
    hi all
    i have a 12v to 5 v converter IC.
    there are two points external to the module which are connected to 12v ic input and ground respectively.
    but instead if they reverse the pins and connect 12v to ground pin and 0v to in i/p the ic burns out.
    so what circuitry should ia dd on the input path of the 12v ic i/p to avoid negative voltages through it
  2. #2
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,797
    Feed the 12V through a suitably rated rectifier diode.
  3. #3
    ponsakthi Newbie
    Join Date
    Dec 2008
    Posts
    29
    diode will dissipate a large amount of heat .. isnt it?
  4. #4
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,797
    Quote Originally Posted by ponsakthi View Post
    As you've provided absolutely no details about the current required, how would we know? - but W = V x I
  5. #5
    ponsakthi Newbie
    Join Date
    Dec 2008
    Posts
    29
    sorry the module takes 1.2 A of current
  6. #6
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,797
    Then the diode will dissipate about 0.84W, use a 3A or 5A diode you should be fine. Bear in mind as well, the regulator will dissipate less power, due to the 0.7V lower voltage supoplied to it.
+ Reply to Thread
  1. Negative Voltage Laser?
    By Splash1 in forum General Electronics Chat
    Latest: 26th December 2008, 09:28 AM
  2. Prevent over voltage on a Cap
    By andy257 in forum General Electronics Chat
    Latest: 12th July 2006, 09:34 PM
  3. help negative voltage
    By japl in forum Electronic Projects Design/Ideas/Reviews
    Latest: 16th March 2004, 01:47 AM
  4. whats negative voltage?
    By flightline in forum Electronic Projects Design/Ideas/Reviews
    Latest: 27th February 2004, 09:40 PM
  5. Negative voltage from a 9V battery?!
    By brodin in forum General Electronics Chat
    Latest: 28th November 2003, 07:10 AM
Tags for this Thread
