I am looking for a schematic for a small amp (20 watt to 4-8 ohm) that I can add to a loudspeaker in my car. The ideal circuit will be co-mounted with the speaker, accept the radio output (originally going to the speaker) as the input, operate from 12 volts, and output designed to drive a speaker. In other words, I want to cut the wire that now goes to the speaker and insert this little amp.
I did a search and found an ideal unit but the IC (TDA1554) is no longer available. Any ideas? Please don't suggest a 600 watt thing with some #8 wires hooked to the car battery - I just want a little boost. |
Check this out: http://sound.westhost.com/projects-1.htm
I hope you'll get it what you are looking for.
"There is no way to peace, peace is the way!" |
I recommend a TDA2005 stereo car amp. in bridge.
For some reason I am having trouble finding the Amp-on-a chip parts such as the TDAA1554 & TDA2005. I tried Jameco and Digikey with no results. Any suggestions?
You can use LM1875. Try this: http://sound.westhost.com/project72.htm
You could try putting an extra speaker
in parallel. |
here.....
the same one as kinjal said http://www.eed.usv.ro/misc/mirrors/c...s/circ0022.htm http://www.tanker.se/lidstrom/hir20a.gif http://space.tin.it/scienza/fladelle/Page2.htm this is all i found for now ....and a lot of tube amps..... ill keep looking |
Thanks to all. The ESP version looks simple and I have found the LM1875 ICs at Jameco. I will need to search for a power supply circuit that will use my car's 12 VDC and produce the +25, -25 volts required by the circuit but I'm ready to get going.
The plan is to beef-up the car's radio - but not with 1000 watts and giant speakers. Instead, I will be building a poor man's version of the current Bose car audio system. They are using single amps co-located with the speakers for some of their car audio - and they sound great. |
This page has a lot of Audio Amp. ICs listed:
http://members.tripod.com/michaelgellis/audioamp.html And some more CAR amps..... http://members.tripod.com/valveaudio/schematics.htm And all calculation stuff.... http://members.tripod.com/valveaudio/Membuatsendiri.htm
