Old 11th February 2009, 08:57 PM   #1
Default stop the battery from over charged how?
I used rectifier circuit to produce 9V and using this voltage i want to charge the battery as well as load will work also.As the main power in off then battery should provide the voltage to load.When the battery is full it must goes to cutoff because not to overcharge the battery like in UPS.
But i didnot find any solution to stop the battery from over charged.
munir is offline
Old 11th February 2009, 09:00 PM   #2
Is that safe? TO blindly feed 9V to the battery all the time even if it's feeding the load at the same time. I don't think it is. THat will cause very high currents through the battery (pretty much a short-circuit) when the battery voltage is below 9V. What you need is an actualy charging circuit that adjusts output voltage to limit the current flowing into the battery.
dknguyen is offline
Old 13th February 2009, 08:36 PM   #3
i uses the diode across the battery to limit the current.
munir is offline
Old 13th February 2009, 08:46 PM   #4
Sorry, but that makes no sense, and at no point have you provided any information to make any suggestions.
battery, charged, stop
LA Battery not getting fully charged sivankls Renewable Energy 18 29th October 2009 07:19 AM
Start-Stop & emergency stop Shohadawy Electronic Projects Design/Ideas/Reviews 2 28th September 2008 12:29 PM
Keeping a battery charged between two voltages Jules Electronic Projects Design/Ideas/Reviews 1 24th July 2004 03:14 PM
Keeping a battery charged between two voltages Jules Electronic Projects Design/Ideas/Reviews 5 23rd July 2004 02:03 PM
Charged battery the wrong way! hantto General Electronics Chat 2 28th January 2004 09:23 PM
