Old 20th March 2003, 10:21 AM   (permalink)
Default high gain amplifier
does anybody have a schematic for listening to sounds trough walls?
i probably need a high gain amplifier, something with low noise....
i might need it to be able to hear what people are saying at far distance, but for this i need a parabolic dish right?
i know there are devices that are already buid and they do that, but i cant find one here and where is the fun if i dont build it?
bogdanfirst is offline
Old 20th March 2003, 01:22 PM   (permalink)
Yes I do have that schematic but its drawn in my collection book and I'll have to scan it. It consists of 741 condenser mic amp. followed by LM386 audio amp. The condenser mic is fitted into a big funnel for better response and directivity.
kinjalgp is offline
Old 20th March 2003, 02:07 PM   (permalink)
please....
i have build something useing 2 LM307(dual op-amp) amps(i think) but i am not satisfied with it. too much noise and i hear all in the headphones.
Old 21st March 2003, 07:15 PM   (permalink)
Hi bogdan,
I found the book and I have scanned the circuit.
Parts List:
R1	= 3.3k
R2 	= 4.7k
R3,R4	= 10k
P1	= 2.2M
C1	= 47nF
C2	= 10uF/25V
C3	= 220uF/25V
C4	= 1000uF/25V
Q1	= AC187
Q2	= AC188
IC1	= 741
kinjalgp is offline
Old 21st March 2003, 07:24 PM   (permalink)
thanks!!
you think that i can hook a LM386 amp to it instead if the 2 transisitors? i already have one build?
Old 21st March 2003, 07:37 PM   (permalink)
You can try it but I think the transistors will give a good current boost which is better than LM386.
kinjalgp is offline
Old 21st March 2003, 10:31 PM   (permalink)
This is not a Hi-Fi equipment,and very old with germanium output stage.I don't understand the C2 on the opamp. output.PNP and NPN base direct connection make high distortions.
Just idea: when You scanned from transparent paper, cover the back with black paper to avoid the reflection from white scanner cover.
Sebi is offline
Old 22nd March 2003, 07:38 AM   (permalink)
This is not scanned from a transparent paper. Its drawn on a notebook paper and the imprint you see behind is of other schematic drawn on the other side of the page.
This circuit is not at all meant for professional use. It is for hobbyists.
kinjalgp is offline
Old 22nd March 2003, 01:00 PM   (permalink)
but where do you think i will find AC transistors? not found here anymore .. they are Ge right? what can i use in place of them? something from the BC or BD series....2N transistors are quite hard to find...
Old 22nd March 2003, 05:45 PM   (permalink)
I guess you can use BD139 instead of AC187 and BD140 instead of AC188. These are not exact replacements but I think they'll work. Right now I am not able to find my transistor selector book, I'll post the replacements as soon as I find it or may be some one can post it if he knows.
kinjalgp is offline
Old 22nd March 2003, 08:04 PM   (permalink)
yes i think that they are appropiate.....
1A will be enough.....
i see the ACs hold 1A too...with beta>65...
o, by the way, what difference is between the AC180 and AC180K ?is it that one has a device attached to is for mounting on the heatsink....?
Old 23rd March 2003, 04:28 PM   (permalink)
kinjalgp,
I don't think the circuit will work with a 741. Pin 3 is an input to a bipolar transistor which requires a forward bias. There is none in your circuit.
pebe is offline
Old 23rd March 2003, 05:16 PM   (permalink)
??? :shock:
The 741 is wired in inverting amplifier mode. What BJT are you talking about? Is it the one which forms the first differential amp. stage of 741? It is not necessary to forward bias the transistor of a differential amplifier.
Well, whatever may be the case, this is a standard inverting amplifier configuration with very high gain which works!
kinjalgp is offline
Old 23rd March 2003, 05:30 PM   (permalink)
i see that the non-inverting pin 3 is connected to the ground wich i see no problem here......
if it was the inverting input to the ground that would mean that the output will be high wich will be a problem, but in another circuit.
Old 26th March 2003, 07:45 PM   (permalink)
Originally Posted by kinjalgp
??? :shock:
Yes, I'm talking about the first input stage. Since when does a bipolar differential amplifier require no biassing?
Take a look at the data sheet. The non-inverting input feeds into a long-tailed diff. amplifier. I'd like to know how Q1 can conduct when its base is at the same potential as the negative rail.
http://www.national.com/ds/LM/LM741.pdf
pebe is offline
