Hi
When I did my circuit (non PWM) I needed to balance the resistances of fixed resistor to themristor. Granted mine was a comparitor arrangement but the thinking may be the same. The resistance of your thermistor at target temperature is essential to know else you wont get any switching. I started with a 10k thermistor and the circuit would not work at all, changed to a 4k7 and viola.
Check the specs and establish the resistance at 140°C, then make the value of your pot suitable to fine tune as you won't match resistances 100%. At 140°C a 100k thermistor will read about 1k6 ohms. I think you may struggle to get the kind of range you want from the PWM as a 100k thermistor has a swing of ± 600ohms in the 130 to 150°C range.
Cheers
Andrew
