Old 1st February 2009, 07:09 PM   #16
Oooops...
i think I was a bit tired when I drew that...
That was meant to be a 5534 op-amp. I just got the number mixed up with a different power amp circuit.
Mixing resistors, yep, need them...
Oh dear, sorry, itīs been a few years...
The resistors below the trims are so that the trims adjust between 66% and 100% of the output voltage... I thought that bit at least made sense when i drew it. I guess the capacitors at the bottom are totally wrong though.
ah well
Wilf is offline
Old 1st February 2009, 07:12 PM   #17
Originally Posted by Wilf View Post
Oooops...
The resistors are as well, sound is logarithmic so the pots will do nothing.
Old 1st February 2009, 09:19 PM   #18
I would try my circuit with another 50k pot facing the other way to the mixer to adjust the overall level. If it does not work well enough then add a dual low current/low noise op-amp.
Maybe the TL072CP is a good choice.
flat5 is offline
Old 12th June 2009, 04:37 PM   #19
Hello,
did anyone had results with this attempt?
I want to make something like this in my accordion and i want to know if this is a good circuit.
thank you
rotava is offline
Old 12th June 2009, 05:03 PM   #20
Default on hold
Hm, sorry, I've put this project on the back burner for a while, so I haven't tested any of these circuits yet. I'll try and remember to post something up here again when I get going with it...
Wilf is offline
Old 12th June 2009, 07:07 PM   #21
If you mail order to get the trimmers and caps and 10k resistors it will be cheap to try. See post #5.
The resistive value of the 50k log trimmers (upside down and backwards) are a guess (there will be three, not two).
I think from Futurlec the parts may cost about $10. Their shipping cost is very little and no min. order.
If you are really interested I could put together a Futurlec parts list for you.
Futurlec, The Electronic Components and Semiconductor Superstore
flat5 is offline
accordeon, electret, mic, mixer, preamp, system
Help with Electret Mic connection? Ventura Electronic Projects Design/Ideas/Reviews 30 13th April 2009 03:32 AM
Electret mic question Sceadwian General Electronics Chat 16 28th August 2008 11:57 PM
Electret Mic crivoli Electronic Projects Design/Ideas/Reviews 4 12th May 2006 05:19 AM
Electret mics again... Dr.EM Electronic Projects Design/Ideas/Reviews 7 10th August 2005 11:45 AM
Electret mic help! Dr.EM Electronic Projects Design/Ideas/Reviews 2 13th January 2005 07:13 PM
