| | #31 |
Thank u guys for the informations and guides, actually I had also gone through those article saying that this product doesn't works, unfortunately I had chosen this project as my final year project, so is there any suggestion so that I can make a little bit effort to improve this project, btw, I am currently using this circuit(as attached) which i found on google, now I am trying to calibrate 10 different frequencies on the CD 4017 IC (as what deepak george did), hopefully some of the frequency really works to repel any pest or rodent.... | |
| | #32 |
The CA3130 opamp in that very old circuit is not made anymore. Are you allowed to simply copy the circuit designed by somebody else for your final year project? Aren't you supposed to design your own project?
| | #33 | |
Sure I will not here it from the 60" HDTV now. | ||
| | #34 |
People who are deaf and old people cannot hear frequencies above 8kHz. A hearing test does not measure above only 8kHz. Old picture tube TVs used a high power high voltage horizontal frequency of 15,750Hz but new TVs are different.
| | #35 | |
| | #36 |
A 741 opamp is 42 years old. It was designed to amplify DC and low frequencies. Its output cannot have a full swing above only 9kHz. At 30kHz its output has a max swing of only 8V p-p. At 30kHz its max voltage gain is only 15. Use an audio opamp like a TL071 that has full output to 100kHz and at 30kHz has a max voltage gain of 100.
| | #37 | |
The new squeaky clean TL071 suffers from phase inversion if you exceed its common mode range. This defect rears its ugly head in circuits like this.
__________________ de KI6RWX | ||
| | #38 | |
The opamp oscillator slowly steps the frequencies of the 555 high frequency oscillator. I wonder if you set the frequencies to play "Mary had a little lamb" over and over and over and over and over and over and ... them maybe it will drive away a pest. Or maybe if you made it loud enough.
| pest, repellent, ultrasonic |
| High Frequency Kid Repellent | Analog | Chit-Chat | 55 | 5th November 2008 08:12 AM |
| Pest Repellent | Mubashir | General Electronics Chat | 26 | 14th October 2006 02:51 AM |
| Building a medium voltage pest control device | mark350 | Electronic Projects Design/Ideas/Reviews | 3 | 9th May 2006 12:26 AM |
| cat repellent | filbert | Electronic Projects Design/Ideas/Reviews | 11 | 28th December 2003 06:12 PM |
| Help making a pest shocker | taftech | Electronic Projects Design/Ideas/Reviews | 6 | 24th July 2003 10:08 PM |
