| hi, i have read the icsp guide in the microchip website (http://ww1.microchip.com/downloads/e...Doc/30277d.pdf) i focused on the 16f8x programming. there is a circuit at the bottom of page 2-21 (figure 1: typical application circuit). i am very noob in icsp/isp and i would like to learn using it... i have several questions that really need clarification: - is the diode found in mclr/vpp already enough? - can a simple tri state buffer be used as an isolation for rb7 and rb6? i found this (http://focus.ti.com/lit/ds/symlink/sn74lvc2g240.pdf) - if i use tri-states, is there a way to automatically switch the gates to its its hi-z state during programming? or i simply need to place jumpers/dip switches to make it hi-z? if there is further information that may be useful, plese feel free to add... thanks! | |
| | (permalink) | ||||
| speaking of isolation, i was just puzzled by this circuit: (http://www.jdm.homepage.dk/icsp.htm) is this circuit good enough for icsp? | |
| That's basically the same as the circuit in microchip's App note. though, the VDD system is better, using a diode in stead of a resistor, like i said | |
| what about the resistors found in the rb6 and rb7? | |
| Like i explained in the previous post, if you use these 2 pins to drive something, a transistor perhaps, then it will work fine, the 2 10K resistors work nice as base-current limiting resistors, and because the rest of the application should be turned off while programming there isn't anything that will respond to the programming signals. If you want full I/O functionality from those pins it would be better to add some kind of isolation, such as your tri-state for example | |
