+ Reply to Thread
Page 2 of 2
First 1 2
Results 16 to 20 of 20
Thread: changer reduces LM317 power dissipation
  1. #16
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,124
    There are a couple of errors in my circuit.
    There should be a diode in reverse parallel with the relay coil.
    Another thing I've overlooked is that it could be oscillating because the filter capacitor is being discharged when the coil is activated causing the output voltage to drop slightly resulting in it being deactivated.
    I can think of two solutions:
    Add a capacitor from the transistor's base to 0V. This might help keep the transistor on for a long enough length of time for the relay to connect to the higher voltage tap.
    Add a high value resistor (try 100k to 1M) from the + side of the rectifier to the transistor's base. This should add some hysteresis so when the relay does engage the transistor will turn on even more.
    Failing that, are you sure the filter capacitor is large enough?
    What's the secondary voltage of your trasformer?
    I would recommend using the solid state version: it should be much more reliable.
    You might have to tweak a few component values, remember I haven't tested or simulated any of these circuits.
    if I know the answer.
  2. #17
    BOOJAN Newbie
    Join Date
    Mar 2009
    Location
    Skopje-Macedonia
    Posts
    20
    i have tryed all what you have posted, but i forgot to menton it in the prevous post....i will try the solid version tomorow or some other day when i will have time
  3. #18
    fernando_g Newbie
    Join Date
    Mar 2009
    Posts
    115
    Hero; your circuit is a very nice to reduce the regulator heat dissipation.
    However, you do need to consider adding hysteresis to the switching transistor.
    Otherwise, right at the voltage threshold, the circuit will start to misbehave between the two states.
    The easiest, of course is to have an opamp with positive feedback.
    But if you would like to maintain an all-discrete design, there is a two transistor design which has been designed eons ago. Lots of info by googling it.
  4. #19
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,124
    The solid state version already has hysteresis built-in, there's no need to add an op-amp.
    Positive feedback is accomplished by adding a 470k resistor from the collector of the PNP transistor top the base of the NPN transistor. When the NPN transistor turns on a bit, it will turn the PNP transistor on which will also apply a higher voltage to the base of the NPN transistor via the 470k resistor.
    I didn't design any hysteresis into the relay version because relays already have some degree of hysteresis built-in. However I neglected the fact that because it breaks before makes it's prone to oscillation (as I mentioned above).
  5. #20
    fernando_g Newbie
    Join Date
    Mar 2009
    Posts
    115
    Quote Originally Posted by Hero999 View Post
    You are correct, I hadn't paid attention to the 470k resisitor.
+ Reply to Thread
Page 2 of 2
First 1 2
  1. interpreting power dissipation table of an LDO
    By bigfarmerdave in forum Datasheet/Parts Requests
    Latest: 16th January 2009, 02:52 PM
  2. power dissipation
    By gargi_khullar in forum Electronic Projects Design/Ideas/Reviews
    Latest: 13th October 2008, 12:09 AM
  3. Power Dissipation in a resistor (pulsed signal)
    By cava0035 in forum General Electronics Chat
    Latest: 14th August 2008, 12:48 AM
  4. Power dissipation problem
    By Electronics4you in forum General Electronics Chat
    Latest: 8th February 2007, 09:16 AM
  5. Power dissipation of PIC
    By akg in forum Micro Controllers
    Latest: 20th December 2005, 09:47 AM
Tags for this Thread
