Old 15th January 2009, 09:41 AM   #1
Default Help with 5,10,15,20,25,30 min countdown timer
I have bee trying to find a circuit diagram for 5,10,15,20,25,30 minute selectable countdown timer. the closest I have found is this one here.
Descriptipn:
A switched timer for intervals of 5 to 30 minutes incremented in 5 minute steps.
Notes:
Simple to build, simple to make, nothing too complicated here. However you must use the CMOS type 555 timer designated the 7555, a normal 555 timer will not work here due to the resistor values. Also a low leakage type capacitor must be used for C1, and I would strongly suggest a Tantalum Bead type. Switch 3 adds an extra resistor in series to the timing chain with each rotation, the timing period us defined as :
Timing = 1.1 C1 x R1
Note that R1 has a value of 8.2M with S3 at position "a" and 49.2M at position "f". This equates to just short of 300 seconds for each position of S3. C1 and R1 through R6 may be changed for different timing periods. The output current from Pin 3 of the timer, is amplified by Q1 and used to drive a relay.
Parts List:
Relay 9 volt coil with c/o contact (1)
S1: On/Off (1)
S2: Start (1)
S3: Range (1)
IC1: 7555 (1)
B1: 9V (1)
C1: 33uF CAP (1)
Q1: BC109C NPN (1)
D1: 1N4004 DIODE (1)
C2: 100n CAP (1)
R6,R5,R4,R3,R2,R1: 8.2M RESISTOR (6)
R8: 100k RESISTOR (1)
R7: 4.7k RESISTOR (1)
Circuit by Andy Collinson
Source: zen's circuit directory
Problem is I want to cast the whole thing in resin so as to make it waterproof so I would like to make the selector work via magnetic switch (as well as the start/stop switch) also I would like to include LEDs to indicate which setting is selected, can anybody help with the design for me?
Ultimately it will need to control a relay that will start a 200w 12v motor which will need to run for the selected time and then shut off
taranakiguy is offline
Old 15th January 2009, 11:24 AM   #2
Isnīt there a double throw range for your S1 component?
didimus is offline
Old 15th January 2009, 07:53 PM   #3
you could use a modification of tarnankiyguy's design. Just use the initial timer setting of five minutes and connect the timer output to a decimal counter (HCF4017). You'll have to adjust the basic 5 min setting and the rest will be as accurate as the basic setting. That way you might use 9 different time settings.
Using a DIP-switch to select the desired time will not be a problem. Otherwise use a single pole 12 throw rotary type switch and limit it to ten positions. (One position for OFF)
Boncuk
Boncuk is online now
Old 15th January 2009, 08:29 PM   #4
Double posting is not a good idea:
variable 5,10,15,20 minutes timer circuit
Now you have two threads, and people who are helping in one, may not know what others are telling you.
BeeBop is offline
Old 23rd May 2009, 06:13 AM   #5
Did you have a reply in regards to using a reed switch's to activated the timing circuit at diferent times that is required
Descriptipn:
Notes:
Parts List:
S1: On/Off (1)
S2: Start (1)
S3: Range (1)
IC1: 7555 (1)
B1: 9V (1)
C1: 33uF CAP (1)
Q1: BC109C NPN (1)
C2: 100n CAP (1)
steveo is offline
countdown, min, timer
countdown timer RoyalMaster Electronic Projects Design/Ideas/Reviews 6 10th June 2007 09:14 AM
555 timer countdown admeech29 Electronic Projects Design/Ideas/Reviews 4 27th May 2007 02:38 AM
Countdown Timer ParkingLotLust Electronic Projects Design/Ideas/Reviews 17 15th August 2006 05:02 PM
can anyone help me with a countdown timer? dicko44 Electronic Projects Design/Ideas/Reviews 2 24th July 2005 07:33 AM
Countdown Timer ctduong1 Electronic Projects Design/Ideas/Reviews 6 2nd November 2004 05:50 AM
