Old 13th January 2009, 12:35 PM   #1
Default Don't know what to call this circuit
Hi every1
I'm looking for a circuit that will activate a relay of 12v DC only if 12v is supplied for longer then let's say 5seconds. This is for a stand alone IR alarm unit. I want to take the output of the speaker when it's alarming and put it through an op amp so that I can activate something else when the alarm is going off. But the problem is when the alarm is activated and deactivated with the remote it makes a beep noise. So if I can build a circuit that will only be activated after 5seconds or so it will work.
Kadett200is is offline
Old 13th January 2009, 12:39 PM   #2
Originally Posted by Kadett200is View Post
Hi every1
Get the datasheet for the 555 timer ic.
Datasheet Archive - Free Datasheet Search Engine :: PDF Datasheets :: Data Sheet :: Datasheet :: Application Note : ??? : ??? : ???? : ????? : ??????? : Fiche technique : Datenblatt : ????????
555 Timer/Oscillator Tutorial
ericgibbs is offline
Old 13th January 2009, 01:23 PM   #3
Thanx. Will look through it.
call, circuit
What do you call a circuit that switches... downplay General Electronics Chat 14 9th April 2008 09:25 AM
LED christmas light switch (what would you call a circuit like this?) Andy1845c General Electronics Chat 14 1st December 2007 04:24 PM
Call Them Ayne Micro Controllers 16 17th January 2007 04:58 PM
Age call !!!!!!!!!!! Emantra Chit-Chat 77 18th November 2005 12:03 PM
What do you call that!!!? electronic mind General Electronics Chat 2 11th March 2005 07:08 PM
