I'm looking to make a large array of high power leds. I have found a power supply that would work well for my application, however, it is not avaliable from any of the vendors that list it worldwide, nor can I contact the company that makes it. the driver is listed here... DealExtreme: $17.75 700mA 40V-68V Constant Current LED Driver (110V~240V AC Input) Is there someway to make this driver from scratch, and possibly modify it to better suit my needs? I would like to be able to get as much as 100v dc out of it and be able to dim the current, but that can come in a later revision. I'm not asking someone to do all the work for me, although that would be nice. I would really like to understand how to safely go from ac to dc and how to regulate the current. Any resources would be greatly appreciated. | |
Supertex HV9910
That component no longer seems to be in production.
Ok.... I've looked through the documation for this chip and it seems like it should work for me. Attached I have the Datasheet for the chip and an example from Supertex running at 350mA. I am trying to make a circuit that will give me 700mA form a 110V line. I can't see where they are getting some of the component values for the 350mA driver. I'd like to understand their example befor eI try to change it. Would anyone be willing to take me through the equations fo rthe 350mA driver so I can have a better understanding of it. thanks | |
| | #6 |
well for starters to get that much voltage off of a 110V line you need to be looking at http://www.supertex.com/pdf/app_notes/AN-H50.pdf instead. Perhaps if you have a specific question after looking at the AN-H50... Dan | |
| | #7 | |
You need to put at least 102vdc into it. Further, if each LED voltage tolerance is +/- 1v, the tolerance of a string of 30 is (30*1)^0.5 = +/-5.5v, not +/- 30v. Last edited by Willbe; 29th January 2009 at 08:47 PM. | ||
| constant, current, driver |
| constant voltage, constant current Lead Acid Battery Charger | Erwin_Macaraig | Micro Controllers | 1 | 4th October 2008 01:26 AM |
| Constant DC current source | Affan | Electronic Projects Design/Ideas/Reviews | 26 | 4th May 2008 01:38 PM |
| constant current source | unlv007 | Electronic Projects Design/Ideas/Reviews | 13 | 25th April 2008 06:51 AM |
| Constant Current Source | pandaemonium | General Electronics Chat | 5 | 25th November 2005 03:51 AM |
| Will current Mirror circuit deliver constant current to LED? | Haru | General Electronics Chat | 10 | 14th April 2005 11:07 AM |
