Old 13th December 2008, 04:31 AM   #1
Question pulse generator(like help)
I am a recent tech school grad and am trying to build a pulse generator for final testing of my company`s product. The pulse generator would simulate a flywheel which is supplied by the customer at their site so you see my need for this project. I have been thinking about a simple 555 timer circuit connected to a transistor(if necessary) switching a relay, passing 24v to the input of a plc. the 24v is already supplied by a power supply. Any ideas? Has anyone worked with this circuit? It does`nt have to be the said circuit, just an on, off, on, off.
jesseyma07 is offline
Old 13th December 2008, 05:14 AM   #2
I would assume the "flywheel" sensor outputs a square wave that swings from 0V to 24V? At what frequency or interval does it do this?
kchriste is online now
Old 13th December 2008, 05:30 AM   #3
Here is a simple timer circuit. Its frequency is ~1Hz. You can change according to the data sheet formulas.
You can't switch 24V using an NE555 timer IC. Its maximum supply voltage is 16V. However if you want to activate a 24V-relay connect an NPN-transistor with a 10K base resistor to the IC output. Connect 24V to the relay and the other side to the collector. The emitter connects directly to ground. Don't forget to use a free wheeling diode in parallel with the relay coil (cathode connected to 24V). Depending on the relay the transistor would live long or may be fried right away.
Boncuk
Boncuk is offline
Old 20th December 2008, 05:38 AM   #4
Default Thank you.
Been very helpful. I remember this circuit from one my first labs in school. May go with a relay that has pulse circuitry combied in one package.
generatorlike, pulse
pulse generator patroclus General Electronics Chat 5 20th February 2007 05:00 PM
pulse generator mmajid Micro Controllers 1 19th March 2006 03:55 PM
pulse generator james10pl Electronic Projects Design/Ideas/Reviews 1 27th February 2004 10:36 AM
pulse generator dark_conqueror Electronic Projects Design/Ideas/Reviews 6 28th November 2003 10:25 PM
5V Pulse Generator Brocktune General Electronics Chat 3 4th November 2003 09:11 PM
