Old 4th May 2004, 07:50 AM   (permalink)
Default Please Help me!!!
Hi!
i would like to build a wireless system.Especially i want 'take' the output voltage of 28 flow sensors. i will use RF Modules at 433 MHz.I Know that i must use encoders/decoders but i dont know how!!! the dip switches of the encoder circuit are for the diffirent addresses of the sensors???
where i will connect the voltage output of the sensor???
thanks anyway
auto_mitch is offline
Old 4th May 2004, 10:21 PM   (permalink)
I assume you will sample the flow sensors so you only need one transmitter and one receiver. Why use RF? What distance and what terrain in the transmit path? The flow sensor output is probably low so amplifiers will be needed? A microprocessor would be handy, but you could make a sequencer with discrete components. I built a transmitter/receiver system using Q-kits and Yeago ceramic antenna. It works beyond 300 feet, no problem.
Russlk is offline
Old 5th May 2004, 09:00 AM   (permalink)
hi!
i want to check all the flowmeters at the same time with multitasking on the microcontroller system, i think that i need many transmitters and one receiver Do u know if i must amplify the sensor's signal before i will connect it at encoder's input?
I use RF modules because the work at 433 MHz and they are suitable for domestic applications.
Can u send me the circuits of your application???
Thanks a lot!!!
Old 5th May 2004, 01:53 PM   (permalink)
There are too many unknowns here: What is the make and model of sensor? What kind of encoder do you plan on using? How are you going to seperate the signals at the receiver? How fast can the flow rate change and how fast do you have to respond to changes? Are there 28 outputs to be controlled?
Russlk is offline
Old 5th May 2004, 02:08 PM   (permalink)
Yes you can use many transmitters. I did a design for a similar type of application, using 6 devices all transmitting to one receiver.
All the remote TX's were pic controlled, all having there own unique code, I only had to monitor an on/off alarm situation & battery voltage, via the A to D input. The receiver and associated Pic had no problem working out which device was sending data and could read the battery state easily.
If all your flow sensors are near to each other? a PIC at that end could be used to analyse the info and just send the ident codes for each sensor, Plus the value your trying to read? if your sensor output is not analog? just a go/no-go output, this should be fairly straight forward. I assume you don't want to go down the multiplexing route
Steve
Crofty is offline
