Old 9th December 2008, 09:27 AM   #1
Default 741 comparator - help
I have a triangle wave input (10 Vpp) and a reference voltage of 5 V. The output square wave should look something like this:
I haven't found any simple instructions on how to go about making this but it should be a simple thing. My simulation is in the attached picture.
So the output is not aligned properly with the input... I tried to mess around with the resistors but it didn't do much.
Any hints would be greatly appreciated.
E: The frequence is 1 kHz.
asdad is offline
Old 9th December 2008, 12:54 PM   #2
One problem I see is you are sampling into the inverting input so your square wave will be upside down, 180 degrees out of phase.
flat5 is offline
Old 9th December 2008, 01:02 PM   #3
Whats the frequency of the triangular waveform.??
ericgibbs is offline
Old 9th December 2008, 02:53 PM   #4
The following circuit should work. Without the MOSFET, the output cannot swing to both rails due to the saturation characteristic of 741 output stage.
L.Chung
eblc1388 is offline
Old 9th December 2008, 03:27 PM   #5
Okay, I changed it to non-inverting, added a third resistor and adjusted all the resistors. Works great now. Thanks!
asdad is offline
Old 10th December 2008, 02:22 PM   #6
If you have the time/patience would you please post the final circuit?
I'd like to know where the new resistor is, etc.
flat5 is offline
Old 10th December 2008, 03:23 PM   #7
Sure.
There's some rise/fall time but it does its job.
asdad is offline
741, comparator
i need help on comparator xiaoxiao General Electronics Chat 3 27th October 2006 04:53 PM
Comparator paladugu Electronic Projects Design/Ideas/Reviews 11 3rd February 2006 12:46 AM
741 as a comparator 4electros General Electronics Chat 8 22nd October 2005 09:53 PM
the right comparator xmat Electronic Projects Design/Ideas/Reviews 6 25th April 2005 06:03 PM
comparator louislu Electronic Projects Design/Ideas/Reviews 4 4th August 2004 07:32 PM
