Old 2nd December 2008, 01:55 AM   #1
Default Basic knowledge in Passive Filter Design
Dear everybody.
Hi..., see u all again.
As mentioned in the title above, I need some technical advises from u all guys about designing a passive filter design.
I need a 'pie filter design', in which an inductor is sandwiched by 2 capacitors to ground.
The purpose is to block any frequency below than 2.5MHz from entering the main communication equipment.
The filter will be located at each end line of my power protection circuit line. There will be 3 sets of this filter.
Hmm... I am not sure about the load resistance... this one, how could I define the load.... I am really unsure...
So, could u all guys give me some advises for designing this pie filter ??
Qq
qq8807 is offline
Old 2nd December 2008, 02:26 AM   #2
Don't you mean that you want to block frequencies above the 2.5Mhz cutoff point?
Googling found this Lowpass PI filter calculator and this Hipass PI filter calculator.
kchriste is offline
Old 2nd December 2008, 02:43 AM   #3
Is a pie filter for removing the seeds from the apples?
Carl
Curmudgeon Elektroniker
crutschow is offline
Old 2nd December 2008, 02:59 AM   #4
Hmm... I forgot something to add....
The current that flow in the line is 2.6A maximum....
qq8807 is offline
Old 2nd December 2008, 03:13 AM   #5
Originally Posted by qq8807 View Post
Dear everybody.
Qq
Do a search on filter calculators, there are many free ones available. Input and output impedances is something you have to bring to the formula as well as the 3db cutoff frequency. You don't normally design and build a filter and then measure to determine what it's input and output impedances are, it's something you have to know from the attended application.
There are many different kinds of filter circuits each with different calculation methods. Different filter models offer different optimazations as to output ripple content, slope shape, passband attenuation, etc. If can be a pretty complex topic that is heavy on the math. However modern computer programs have taken a lot of the pain away.
Good luck
Measurement changes behavior
Leftyretro is offline
Old 2nd December 2008, 03:21 AM   #6
Thanks a lot for the helps from kchriste, Leftyretro & crutschow.
By the way, I need to check the impedance of the intended application, right ?? :/
qq8807 is offline
Old 2nd December 2008, 03:42 AM   #7
Only if you want to be able to calculate the values of the components needed
basic, design, filter, knowledge, passive
Analog Filter Design jnnewton Electronic Projects Design/Ideas/Reviews 5 11th December 2007 01:45 PM
Inverter Output Filter Design alisarhangpour General Electronics Chat 10 29th April 2007 02:17 PM
Filter design advice zachtheterrible General Electronics Chat 2 11th March 2006 11:58 PM
Filter design fergcu General Electronics Chat 6 15th April 2005 04:13 PM
LC filter design dm927 General Electronics Chat 0 20th February 2004 05:57 AM
