+ Reply to Thread
Results 1 to 7 of 7
Thread: Simple S R Relay Circuit
  1. #1
    SirBob Newbie
    Join Date
    Nov 2008
    Posts
    6
    Default Simple S R Relay Circuit
    Hi I've got a simple SR relay circuit. As Shown
    My question is could I put a capacitor across S2 to get the relay to reset everytime the circuit is powered up?
    If so what type (I'd guess at an electrolitic) and how would I work out what size would be required?
  2. #2
    kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent
    Join Date
    Jul 2006
    Location
    Victoria BC, Canada
    Posts
    3,681
    Quote Originally Posted by SirBob View Post
    You could, but that could be a little hard on the Reset switch. A better solution is below. Note that I also added catch diodes across the relay coils. You can only eliminate those if they are built into the relay. The size of the capacitor depends on the current and pulse time requirements of the SR relay. It also depends on the power supply voltage rise time.
  3. #3
    SirBob Newbie
    Join Date
    Nov 2008
    Posts
    6
    Hi, thanks for the answer
    What is the discharge resistor for would the capacitor not discharge through the relay? (please don't take the question the wrong way, I'm not argueing wether it should be there, I'm just trying to get an understanding of the circuit. )
    The relay coil is 800Ω 15mA. Min switching voltage 8.4V, Switching time (max) is 5ms.
    The power supply rise time would be pretty quick (i'd think) as it's a 12v car battery.
  4. #4
    KMoffett Excellent KMoffett Excellent KMoffett Excellent KMoffett Excellent KMoffett Excellent
    Join Date
    Oct 2007
    Location
    Minneapolis MN USA
    Posts
    1,385
    Depending how frequently the 12v in turned on, you may need a discharge path for the capacitor, so it will be discharged fully after the 12v power is turned off.
    Ken
  5. #5
    SirBob Newbie
    Join Date
    Nov 2008
    Posts
    6
    I see, Thanks
    That would that need to be quite a high resistance I'd imagine so as not to drop the voltage across the relay coils?
  6. #6
    Join Date
    Jul 2006
    Location
    Victoria BC, Canada
    Posts
    3,681
    No problem. The capacitor wouldn't discharge through the relay because of the diode I added to prevent S2 from discharging the capacitor. Hence the need for a discharge resistor. You could also use a diode.
    If you use a 100uF 25V capacitor and a 4.7KΩ discharge resistor, then you'll get a nominal 19ms pulse for the relay. By 19ms pulse, I mean that the voltage across the coil will be higher than 8.4V for 19ms. The tolerance on most small electrolytics is around +-20% so your timing will vary with different capacitors.
    I assume it'll be switched by the key in a car? That should be a pretty quick rise time. It wouldn't be cycled that quickly so a 4.7KΩ discharge resistor will be fine.
  7. #7
    SirBob Newbie
    Join Date
    Nov 2008
    Posts
    6
    Many thanks, I'll dig out some bits + start soldering.
+ Reply to Thread
  1. Simple relay circuit getting noise spike form AC line
    By creichard in forum General Electronics Chat
    Latest: 10th August 2009, 08:28 AM
  2. Simple relay switch - but how?
    By daveguk in forum Electronic Projects Design/Ideas/Reviews
    Latest: 22nd October 2008, 12:06 AM
  3. Need A Simple Timed Relay
    By chads in forum Electronic Projects Design/Ideas/Reviews
    Latest: 3rd June 2008, 08:04 AM
  4. Simple relay question..
    By Swifty in forum Electronic Projects Design/Ideas/Reviews
    Latest: 10th February 2004, 04:31 AM
  5. simple Time delay relay circuit
    By Fletcher in forum Electronic Projects Design/Ideas/Reviews
    Latest: 14th October 2003, 02:05 AM
Tags for this Thread
