| My first problems is: Ok i am doing some VHDL code. right now i have 2 VHDL source which is functioning as it suppose. now i like to combine booth, but i dont want combine it in one source file. What i like to do is to create third source file, than when ever i need that function i just call it. for example: 1) ADDER.VHDL 2) MULTIPLIER.VHDL 3) TOP_SOURCE.VHDL so in top_source.vhdl, if i need adder operation i just call adder.VHDL to perform the operation. if i not misunderstand it will used port mapping to transfer data to subprogram and from sub program. it like subroutine in C or any other programming language. can somebody show me how to o this or provide me with an example or website that have the solution to the problems. My second problems is: how to crate behaviour to do set 1 operation first than followed by set 2 when set 1 program finished. if in C or any other language, instruction executed line by line. but in VHDL it being executed all at the same time. How can i crate a code let say will add 2 number first than subtract with something and all code written in same process under same behaviour. If cannot! what is the best way to do that. I thank you in advance. | |
| For the first: you can use components, for the next problem: you can use state machin | |
| Thanks, i will search all my book for how to convert the code to be component. by the way! if you have a good example, please share it wth me. for second, i thought there must be other ways to run from state machine! since i preaty weak at this, well, look like i have to faced it. Thanks | |
| Component: entity XX is port(....); end XX; architecture XXX of XX is ... End XXX; Main Prog: entity YY is port(... local_s1: out std_logic ); end YY; archtecture YYY of YY is Component XX port(..The same of the original...); U1:XX port map(... --map signals to loacl signals. for ex: sig1=>local_s1; }; State Machine type States is(Idle,st1,st2); Signal CS:States; begin process(Clk,CS) begin if rising_edge(CLK) then case cs is when IDLE => cs<=ST1; when ST1=> cs<=st2; when st2=> cs<=IDLE; when others=> cs<=idle; end case; end if; end process; | |
