+ Reply to Thread
Results 1 to 5 of 5
Thread: Problem w/astable flasher circuit
  1. #1
    tap364 Newbie
    Join Date
    Mar 2008
    Posts
    3
    Default Problem w/astable flasher circuit
    Hi all, I'm having trouble with a simple 2 NPN transistor astable flasher circuit. It's a typical circuit seen everywhere and my outputs on each side are driving solid state relays that turn on a string of C7 lights each cycle. My timings are long, about 3sec on, 5sec off, and the circuit works fine. The problem is when I breadboard 3 or 4 circuits together all with different timings, they tend to start "synching up", flashing together, rather than maintaining their individual flash rates. I've tried different RC values and still have the same problem. Does this sound like normal behaviour when running these circuits together? My bench supply is a very stable DC, so I don't think it's power related noise. I figure that when one circuit switches, it's also triggering another circuit that's close to its switch point. Is there a way to isolate them without using separate supplies for each circuit? I eventually would like to run the finished board with a simple (and cheap) 6-12V wall wart. Is there a better circuit to do what I need, i.e. 555? My projects will need from 3 to 6 of these flasher circuits on a single board eventually. If I need to provide any more details I will do so gladly! Thanks for any insight into this. TP
  2. #2
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,849
    Blog Entries
    13
    What onboard power rail decoupling caps do you have.? electrolytic and ceramic.?
    Link to my Articles: http://www.electro-tech-online.com/a...icgibbs-55450/
  3. #3
    tap364 Newbie
    Join Date
    Mar 2008
    Posts
    3
    Hi Eric, thanks for the reply. Sadly I had no caps on the power rails. Your suggestion prompted me to research the use of decoupling caps. Put a 103M ceramic across each stage and the circuit is working perfectly! Will probably need some filter caps when switching to the wall wart though. Still learning, just needed a nudge in the right direction. Thanks again! TP
  4. #4
    eblc1388 Excellent eblc1388 Excellent eblc1388 Excellent eblc1388 Excellent eblc1388 Excellent
    Join Date
    Jan 2005
    Location
    UK
    Posts
    2,226
    Quote Originally Posted by tap364 View Post
    Nice. Many years ago some scientists also discover that different mechanical clocks also sync together if they are placed on the same shelf. I guess this is the equivalent in the electronic world.
    Sadly its the fact of life that it happens when one don't won't it to happen, and people have gone to great trouble to make it happen but they just won't.
    I would say for sure if one starts out "to make 3 or 4 circuits together" hoping they would sync in flashing would end up having each circuit flashing by its own.
    L.Chung
  5. #5
    tap364 Newbie
    Join Date
    Mar 2008
    Posts
    3
    Never heard of the clock analogy before. However, I have heard of fireflys syncing their cycle after awhile. Apparently true also with a group of female co-workers, if you know what I mean . But you're right, would never happen if that's what I wanted.
+ Reply to Thread
  1. Relay control seems fine but goes astable when circuit is added
    By mijenak in forum Electronic Projects Design/Ideas/Reviews
    Latest: 22nd November 2008, 11:02 PM
  2. Monostable and Astable multivibrator circuit using CMOS gates
    By olgaPB in forum General Electronics Chat
    Latest: 24th October 2007, 07:29 AM
  3. Problem in LED Flasher in pic 16F877A
    By rakan in forum Micro Controllers
    Latest: 7th April 2007, 10:45 AM
  4. astable multivubrator circuit help
    By erictham83 in forum General Electronics Chat
    Latest: 20th August 2006, 10:36 PM
  5. Problem simulating astable 555 circiut
    By joe31 in forum General Electronics Chat
    Latest: 21st November 2003, 09:10 AM
Tags for this Thread
