Old 17th November 2008, 12:23 PM   #1
Question 1 kHz pulse generator using NE555
--> This is my exact task given. To design a oscillator circuit that produces a 1kHz clock signal using a NE555 Timer IC.
There has to be an output on the oscillator circuit such that the output can be connected to another board. a RED LED should also light when power is being supplied to the board .
- Design document showing any design and calculations.
- schematic capture of design
- PCB Layout
SPECIFICATIONS
power - a tester shall be powered by a 9V battery. a batery clip shall be used to connect the battery to the PCB board.
voltage regulation - you might need to regulate your supply to 5V
provide a pin header for common Ground connection
- If u can help me , plz reply! thank you!!!!!
deva_raj24 is offline
Old 17th November 2008, 12:37 PM   #2
There're a lot of information about 555 timer, just google it. The datasheet even provides the schematic.
bananasiong
bananasiong is offline
generator, khz, ne555, pulse
pulse generator danno Micro Controllers 8 31st October 2007 11:07 PM
pulse generator mmajid Micro Controllers 1 19th March 2006 03:55 PM
pulse generator james10pl Electronic Projects Design/Ideas/Reviews 1 27th February 2004 10:36 AM
pulse generator dark_conqueror Electronic Projects Design/Ideas/Reviews 6 28th November 2003 10:25 PM
5V Pulse Generator Brocktune General Electronics Chat 3 4th November 2003 09:11 PM
