Old 16th November 2008, 11:19 PM   #1
Default LM317 voltage regulator parallel connection
Hi
Since each LM317 volt. reg IC can supply only a maximum of 1.5amps, how could i connect 2 or more LM317 voltage reg. ICs in parallel in order to increase the current output capability at the output to supply 3-4 amps at the same variable voltage output.
Thanx
Haas is offline
Old 16th November 2008, 11:28 PM   #2
Use an LM350 for 3A, or a LM338 for 5A.
Go Trojans!
saturn1bguy is offline
Old 16th November 2008, 11:33 PM   #3
Use a pass transistor.
http://ourworld.compuserve.com/homep...den/page12.htm
flat5 is offline
Old 16th November 2008, 11:39 PM   #4
Originally Posted by Haas View Post
Hi
Thanx
You can use current sharing resistors on the outputs, and maybe output diodes so that the regulators only source current, but then you sacrifice the low output impedance regulators provide you, in return for simplicity.
Willbe is offline
Old 17th November 2008, 02:11 AM   #5
Default lm327
There is a 5 amp version, but it's in a different package than the 1.5 amp version.
microtexan is offline
Old 17th November 2008, 03:26 AM   #6
The LM338 is the 5A version, as mentioned above. And the LM317 and LM338 are both offered in similar packages, namely the TO-220 (LM317T/LM338T) and the TO-3 (LM317K/LM338K).
Go Trojans!
Old 17th November 2008, 06:04 AM   #7
Although a solution is already covered, hooking up two V regs in parallel is bad juju in general, as which ever is slightly biased higher, it will supply all of the current
digital-diy.com - Hobby microcontroller projects and tutorials. Assembly, PICBasic and C examples.
gramo is offline
Old 17th November 2008, 05:14 PM   #8
Juju or mojo?
Try it on paper. It's two loops with 3 resistors, one resistor being the load resistor. Assume a 0.1v difference in the IC outputs.
The real problem comes if you remove the load resistor, so if this is a possibility then I recommend output diodes.
Willbe is offline
Old 18th November 2008, 07:16 AM   #9
Thanks for all your responses.
Then can't they have the same adjust pin? with a diode also connected in the adj pin to compensate for the output diodes?
Haas is offline
Old 18th November 2008, 07:19 AM   #10
The LM338T and LM350 are not available where i'm at. That's why i thought of a way to accomplish the same job using the LM317Ts - which are readily available here.
Haas is offline
Old 18th November 2008, 07:59 AM   #11
You can't get an LM338T in "does it matter?" Wow. (It's called go to Jameco or DigiKey online and order some )
If you really can't get one then I'd stick with using a pass transistor on a single LM317, as previously suggested by someone...
Go Trojans!
Old 19th November 2008, 07:39 PM   #12
Default speaking of parallel. . .
Electronic Design Welcome for 11.17.08 has an article [ED online 20023] where the author, Bruhns, parallels two LT3080 regulators.
Sort of. . .
Willbe is offline
connection, lm317, parallel, regulator, voltage
voltage regulator chips in parallel? HiTech General Electronics Chat 12 4th January 2007 08:44 PM
how to verify parallel connection?? miaomiaooh General Electronics Chat 5 6th October 2006 06:40 PM
LM317/350 adjustable regulator question indecided Electronic Projects Design/Ideas/Reviews 4 29th January 2006 09:58 AM
voltage regulator , LM317 gatman General Electronics Chat 8 8th October 2003 08:41 AM
Fan Voltage Regulator LM317 Skylined Electronic Projects Design/Ideas/Reviews 3 8th August 2003 05:14 PM
