Old 15th November 2008, 01:31 AM   #1
Default LED patterns with PIC chip
I am creating a device similar to the one on the link above except I will be using a PIC chip to control the transistors to create special patterns.
One problem I've run across is that if I activated the top transistor on the side and all of ones along the bottom (to turn on the LEDs on the whole top row) how would I then turn on just one LED on the second row? Surely activating the second transistor down will allow the entire row to light because of all the bottom transistors being active?
I'm guessing that either I've gone wrong somewhere (fairly likely ) or that I'm going to need some kind of multiplexing system.
Any advice would be greatly appreciated!
ormo is offline
Old 15th November 2008, 01:41 AM   #2
You forgot your link
This message transmitted on 100% recycled electrons
Andy1845c is offline
Old 15th November 2008, 01:44 AM   #3
CircuitDB | 10 to 100 LED Sequencer Using a Matrix
Sorry, its 01:44 AM here and I'm starting to get a bit tired...
ormo is offline
Old 15th November 2008, 02:58 AM   #4
Yes, that is exactly what you need to do. That way only one row and one column is on at a time. You switch them really fast so several LEDs appear to be on at the same time.
kchriste is offline
Old 15th November 2008, 06:54 AM   #5
The circuit lights one LED at a time in sequence because only one output of each CD4017 is high at a time.
If you speed up the oscillator then all the LEDs will appear to be lighted at the same time but they will look dim.
audioguru is offline
Old 15th November 2008, 10:12 AM   #6
Check my tutorials, which show how to use a 16F628 to feed 64 LED's in a matrix.
chip, led, patterns, pic
Interference Patterns crashsite Math and Physics 4 3rd March 2008 05:21 PM
Follow up on beam patterns Electronics4you General Electronics Chat 4 22nd July 2006 03:53 PM
5x7 dot matrix led display - character patterns davepusey General Electronics Chat 4 15th October 2004 06:13 PM
8-Bit ADC chip pike Datasheet/Parts Requests 2 15th March 2004 05:38 AM
PIC chip potatohead General Electronics Chat 8 16th January 2004 09:37 PM
