| hi, is it possible to produce a (-) negative voltage given a +12V supply? if so, what kind of circuit would produce such? thanks... | |
A lot depends on the current you require, for a low current requirement it should be quite simple - although with a charge pump you will always end up with a little less than -12V. | ||
| Its siple svitch plus and minus. 12V = 0V 0V = -12V
| heres 2 simple ways: use an op amp as an invertor or use a 7912 which is a -12 regulator
__________________ Reality is an illusion. | |
__________________ Dave Pusey. PIC Programming Tutorials: http://www.mstracey.btinternet.co.uk...al/picmain.htm Brilliant PIC Simulator: http://www.oshonsoft.com/pic.html | ||
| couldn't you just use a potential divider? - he didn't say he needed -12v, just a negative supply. | |
| such a divider only works if the load on both the negative and the positive side is the same. If one side has a bigger load voltage will 'tilt' to the other direction | |
| hi my frend u can check the web site of analog devices electronics company http://www.analog.com/ :P | |
| The following circuit will work if you need 100Ma or less. The output voltage will be negative and will be approximately up to 1.1 volts less than the input. There are two versions of the IC that I am aware of LT1054CP by Texas Instruments, and LT1054CN8 by Linear Technology, both available from Digikey.
__________________ The great thing about electronics is unlimited ways to do the job. The only limit is one\'s imagination. I generally think my way is best. Show me a different way. I have an open mind. | |
| What neg voltage ? what current??
__________________ gerty | |
| For your info: An ICL7660 is a Direct Replacement for the LT1054 and Costs only 1/3 the Price. Gary | |
The ICL7660 maximum input voltage for the regular versions is 10V while the A versions it is 12 Volts. Whereas the LT1054 has a maximum input voltage of 15V.
__________________ The great thing about electronics is unlimited ways to do the job. The only limit is one\'s imagination. I generally think my way is best. Show me a different way. I have an open mind. | ||
| Here are the Specs: ICL7660CPA is rated at 10.5 volts, ICL7660ACPA is rated at 13 volts, ICL7662CPA is rated at 22 volts And the LT1054-CN8 is rated at 15 Volts. However, In tests I did with Various Batches of the ICL7660CPA, (with it claimed rating of 10.5 volts) It Works Perfectly OK with voltages up to "AT LEAST 16 Volts". In Addition, I have a Metal Detector Project on my website that runs on a 12 Volt Sealed Lead Acid Battery, However, it Typically delivers 14.5 volts at a full charge. I have used this ICL7660CPA on well over 100 of these units, WITHOUT ANY FAILURES in over a year. I believe all these chips are close to being identical, if not identical. Its more how they want to spec them for a particular price and application. Reminds me of FLEA Powder for Cats and Dogs. They sell Both, But Both are Identical except for the label. However most persons have both will buy both. A Cheap way to increase Sales. Try it Yourself, It is Much Cheaper to buy. Take care.........Gary | |
| Chemelec, you are correct about the specifications of the ICL7660CPA, the ICL7660ACPA, and the ICL7662CPA. So for a 12 volt circuit I would still choose the ICL7660ACPA and the ICL7662CPA. I would hesitate to use the ICL7660CPA in an application that exceeded the manufacture's specifications. That's my opinion anyway. Thanks for proving I was wrong about the ICL7660 series of voltage pumps.
