+ Reply to Thread
Results 1 to 9 of 9
Thread: Using LED drivers as DC/DC converters?
  1. #1
    aanders1 Newbie
    Join Date
    Nov 2008
    Posts
    2
    Unhappy Using LED drivers as DC/DC converters?
    I was told to use this part as a DC/DC converter to make 2.7V - 3.6V (at up to 9A) into 24V-36V at 1 A. (Yes, I know that problem 1 is that the input voltage I have is too small for this chip, but pretending I can double it for now, let's get into the other issues.)
    Like most LED drivers I'm seeing, there is a PWM associated with it. Can these be run at 100% duty cycle to provide constant DC output? Let's just say the device I'm powering would not be happy with fluctuating voltage (mini-CPU) so if not, that's bad.
    Ideally my converter (for the Vo and Vi above) is 90% efficient or greater and fits into a cubic inch. I laughed when I heard the requirements, but then again what do I know.
    In the meantime, I'm trying to get as close as possible. Could it be that an LED driver is the answer? I have trouble believing a chip this small can do this for me with constant current output without massive heat problems at the very least...what am I missing?
    Any suggestions on anything that come close to my requirements?
  2. #2
    Ubergeek63 Excellent Ubergeek63 Excellent Ubergeek63 Excellent Ubergeek63 Excellent Ubergeek63 Excellent Ubergeek63 Excellent
    Join Date
    Apr 2008
    Posts
    1,275
    No way, that thing only has a 1A switch.
    36V*1A=36W ... 36W/2.7V=13A ... with a transformer that allows a 50% duty cycle: 13A*2=26A peak (normally you would be looking at a DC of 2.7/36=7.5% for that voltage ratio or a peak current of 13/.0075=170A).
    Dude, you need a second lithium, at least.
  3. #3
    ronsimpson Good ronsimpson Good ronsimpson Good
    Join Date
    Apr 2007
    Location
    Loveland, CO USA
    Posts
    710
    Look at the FAN5336 or FAN5330
    There are many LED PWMs that work down to 2.7 volt.
    Some work to 36 volts out.
    None I know of work to 9A in (1A out)
    You could parallel up 9 of the FAN5330
  4. #4
    aanders1 Newbie
    Join Date
    Nov 2008
    Posts
    2
    Right. I realize I may need to just line up a bunch of components in parallel to handle the current, though fewer parts is always nice...
    (And yeah, I know my voltage/current ratios don't make V1*I1=V2*I2 work if you take the min in and max out...believe me, I know. That's one of the reasons I need as much efficiency as possible.)
    Does anyone know though if these chips can be driven at 100% duty cycle (PWM) to provide something that looks like DC out?
  5. #5
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,705
    Blog Entries
    5
    100% duty is DC What are you trying to build?
    Bill
    Smart Kits build Smart People
  6. #6
    Join Date
    Apr 2007
    Location
    Loveland, CO USA
    Posts
    710
    100%=smoke!
    There are PWM ICs that drive external transistors where 9 amps is possable.
    Look at ZXSC300.
  7. #7
    Join Date
    Apr 2008
    Posts
    1,275
    Quote Originally Posted by aanders1 View Post
    Fine... max in min out:
    24V*1A=24W ... 24W/3.6V=6.7A continuous ... you are still talking about 14A peak with a 50 % duty cycle worthy transformer and 45A peak with just and inductor. Still far out of the capabilities of single chips and you still have no chance of getting it in one cubic inch...
    Remember, not only do you have to handle the DC current levels the inductor can not saturate at 50A even assuming max in and min out. Not to mention the fact that on a single lithium cell, of say 4AHr, you will get all of 17 minutes of run time, that is assuming it can put out that kind of current continuously without turning into a torch! (that is the voltage of the chemistry in which there are some that will handle it)
  8. #8
    Willbe Good Willbe Good Willbe Good
    Join Date
    Aug 2008
    Location
    MD
    Posts
    1,238
    You know, the link implies that the output of this thing acts like a current source, and not a voltage source. . .is that OK for your app?
  9. #9
    Join Date
    Apr 2008
    Posts
    1,275
    Quote Originally Posted by Willbe View Post
    Actually that depends more on what you use for feedback in many cases, but controllers meant to be current sources always have lower sense voltages.
    Be that as it may, that part has the tiniest fraction of the capacity he is asking for.
+ Reply to Thread
  1. Differences between LED drivers
    By prowede in forum Electronic Projects Design/Ideas/Reviews
    Latest: 14th March 2008, 05:51 PM
  2. LED Re-Drivers
    By crashsite in forum General Electronics Chat
    Latest: 13th February 2008, 01:53 AM
  3. ATI TV Wonder USB DRIVERS!!!
    By Marks256 in forum Chit-Chat
    Latest: 10th December 2006, 02:00 PM
  4. Do I need drivers?
    By digital_dave in forum General Electronics Chat
    Latest: 20th January 2004, 12:27 PM
  5. Help : On RS232 drivers
    By Spasm in forum General Electronics Chat
    Latest: 15th December 2003, 02:01 PM
Tags for this Thread
