Old 14th November 2008, 03:22 PM   #16
OK, so I hooked everything up and then cranked the output of the 317 to it's maximum ~34V. I adjusted the pot on the back of the meter so that it matched the DMM. I then spot checked about 5 different voltages throughout the range and the meter was within ± .1V compared to the DMM. That is more than accurate enough for my purposes. Thanks for the help.
vne147 is offline
Old 1st December 2008, 11:38 PM   #17
Originally Posted by vne147 View Post
Hello everyone. I have a question that I would appreciate your help with. I built a variable voltage power supply a while ago using an LM317. I am just getting around to putting it into an enclosure that will have a digital voltmeter mounted on the outside so that I can quickly see what voltage is being output. The voltmeter I bought when I initially started the project says that it requires an independent 9V power supply. What I think that means is that the 9V for the voltmeter and the measured voltage cannot have the same ground. I attached a schematic of how I plan to do this. The ground for the LM317 portion of the circuit is simply the "-" pole of the bridge rectifier B1 while the ground for the 9V is connected to the 3rd prong of the AC outlet. The voltmeter I will be using in the PM-129A (link to datasheet below). So here are my questions:
1. Is my assumption in this statement, "What I think that means is that the 9V for the voltmeter and the measured voltage cannot have the same ground.", correct?
2. Will the method I am using in the schematic to seperate the ground paths work?
3. Other than using a 9V battery, is there an easier way to acheive an indepent power source for the digital voltmeter other than how I have shown it in the schematic?
4. This question is not related to the design but to information in the datasheet. This voltmeter is supposed to measure 0 - 500 V DC but on the datasheet under the specifications section the maximum input is listed as 199.9 mV DC. How can the voltmeter measure up to 500 V DC if I can't apply anymore than 199.9 mV DC to it? I think I'm misinterpreting the datasheet but can some explain to me what the 199.9 mV DC limit applies to?
Thanks in advance for your help.
Voltmeter datasheet:
http://www.circuitspecialists.com/im...29A&Bspecs.pdf
Schematic:
thaks for circuit
alikfaster is offline
Old 12th January 2009, 06:29 AM   #18
Thank u very much
nonkannan is offline
digital, power, supply, voltmeter
Digital Ac Voltmeter Zh3ng Electronic Projects Design/Ideas/Reviews 1 11th November 2008 03:00 AM
Digital inline dimmer power supply kybert Electronic Projects Design/Ideas/Reviews 28 31st October 2007 01:56 PM
Bipolar power supply with digital control GizmoWizard Electronic Projects Design/Ideas/Reviews 11 15th March 2006 02:53 AM
ac or dc digital voltmeter zeeshan353 Electronic Projects Design/Ideas/Reviews 5 21st September 2005 03:05 AM
Digital Voltmeter sam_h Electronic Projects Design/Ideas/Reviews 3 28th April 2004 07:17 AM
