Old 10th November 2008, 01:19 PM   #1
Default Pic 12f675 - Rs232
Hi i am new to microcontroller and trying to learn PIC controllers, i have completed few examples as mentioned in book, like flashing LED's etc...
Iam stuck with one problem , i am trying to send "Hello" to PC via RS232,
i wanted to see "Hello" in my PC hyperterminal as soon as i power up my PIC board, I have followed all the connections as mentioned in book, i have used MAX232 for serial communication.
I am not able to see "Hello" in Hyperterminal. I even connected LED to PIN 14 of MAX232(T1Out , which is connected to pin 2 of 9 pin D Connector)LED is blinking but "Hello" does not appear on Hyperterminal
Please help me to find solution
Rgds
pkvasan is offline
Old 10th November 2008, 01:25 PM   #2
You might take a look at my PIC tutorials?.
The 12F675 uses the same 14 bit core as the 16F628.
Old 10th November 2008, 03:03 PM   #3
Rgds
Does gibberish (i.e. rubbish characters) appear on Hyperterminal?
If there is none, then you are having wiring connection problems. One cause is a crossed serial cable.
If there are rubbish characters appearing, then your PIC baudrate or Comm settings is probably wrong. This can be caused by bad UART register setup, wrong crystal frequency used or you have the incorrect OSCCAL factory calibrating value loaded if you're using internal oscillator.
L.Chung
eblc1388 is offline
Old 11th November 2008, 04:26 AM   #4
I think there is some wiring problem, it worked once. if check the voltage level at PIN 14 of Max232 i am getting approx 5V continously but i can see any think in hyperterminal. is it only wiring problem or there is any problem in my PC. i checked config setting in hyperterminal and seems to be correct.
pkvasan is offline
pic, rs232
Soft-RS232 on 12F675 ~ Not syncning? johankj Micro Controllers 22 9th May 2008 07:44 PM
12f675 YAN-1 Micro Controllers 2 14th January 2007 08:05 PM
A/D with pic 12f675 ndspinney Micro Controllers 8 23rd December 2006 10:55 AM
PWm using 12F675 Divs Micro Controllers 9 21st December 2006 03:46 AM
rs232 to rs232 data logger with 1meg buffer -help needed ccaammaaccaazzii Electronic Projects Design/Ideas/Reviews 11 20th October 2004 10:43 PM
