Old 27th April 2004, 07:53 AM   (permalink)
Default circuit design
I am doing an electronic project with microcontroller.Here i am reading the flow rate with flow meter which gives 4-20ma.I need a circuit to convert 4-20ma to 0-5volts analog voltage to 0-5volts digital voltage . so that it can be given as input to the microcontroller(89c51rd2).Please help me,so that i can proceed my project
design doubts
vems is offline
Old 27th April 2004, 08:08 AM   (permalink)
What you need is a simple opamp circuit. Look up "non-inverting opamp" on google.
http://ourworld.compuserve.com/homep...wden/opamp.htm
Has some good info.
Brent
bmcculla is offline
Old 27th April 2004, 12:54 PM   (permalink)
Do you want 0 to 5 volts or 1 to 5 volts? The guys who did control work for me used a resistor of the correct value (250 ohms) to yeild a voltage drop of 1 to 5 volts with a current flowing of 4 to 20 ma. We used to avoid spanning to zero because zero is pretty small. That only gets you part of the way there.
stevez
stevez is offline
Old 2nd May 2004, 10:44 PM   (permalink)
I agree w/stevez to use a 250 ohm resistor across your 4-20 loop to
get 1-5VDC. 1VDC=no flow and 5VDC=max flow. Then use an A/D
converter from there to get a digital representation of your flowrate
data into your micro ...
jbeng is offline
