Old 29th October 2008, 11:34 PM   (permalink)
Default Smart Battery Charger Circuit
Hi from Alaska,
As winter is settling in, I am catching up on a few electronic projects on my list and one of them is a smart charger for my RV dc system.
I found a simple circuit on the Internet that provides the adjustment of turning on and off the charging output by setting the max and min voltages for operation.
However, the circuit provided uses abbreviations for component values that I believe are common in some foreign country. For example, there are two variable resistors (with slider taps) with these notations on the circuit:
VR1 500V (no ohms indicated or value like a "k")
VR2 1 K this seems to be a typical 1 K ohm variable resistor
There are three more resistors in the circuit:
R1 3.9 K aslo seems to be a typical fixed 3.9K resistor
R2 290 V another big question mark for me
R3 15 V and another unknown
Is the "V" another code for "ohms" ? Are they typos ?
This circuit uses a single power transistor 2SC1061, a 12 VDC relay, a 1N4001 diode and the resistor network make up a comparative window to turn the transistor on or off which energizes or de-energizes the relay to switch on or off the charging current.
Can anyone clarify for me the values of these five resistors for me?
Thanks in advance, Bill
Alaska Bill is offline
Old 30th October 2008, 12:15 AM   (permalink)
No, 'v' is not another code for ohms, but apparently is used here as a
substitute. 'mf' should be 'uf', also.
Look here for more elaborate chargers:
Power Supply Schematics - page 5
<als>
fsmyth is offline
External battery charger circuit Blueteeth General Electronics Chat 40 6th November 2007 02:48 PM
SMART battery Charger help needed Frosty_47 General Electronics Chat 11 10th September 2007 03:42 AM
battery charger circuit t_sanoop Electronic Projects Design/Ideas/Reviews 11 1st September 2006 09:50 AM
battery charger circuit for 9v pp3 battery anyone ? badflyer Electronic Projects Design/Ideas/Reviews 0 27th October 2003 08:35 PM
circuit charger 12v gel battery please want2 Electronic Projects Design/Ideas/Reviews 1 3rd August 2003 05:10 PM
