I googled for a constant current source and came along the lm317. I both simulated it (in multisim) and built up the simple circuit, but I neither get a constant current when i attach a load! I followed this circuit: http://www.roboternetz.de/bilder/konstantlm317.gif. Everything is fine if the circuit remains open, however attaching a load let the current drop significantly. Do you see any failures in "my" design? Thanks | |
You don't give any details of what you've done, what the source is, or what the load is.
Yes the battery symbol and terminals don't match.
| | #5 | |
| | #6 |
hehe, just make it in the actual... just replace parts if it is blown. ![]() success is a series of failure! goodluck
__________________ every moss and cobweb scars of a failing heart | |
| | #7 |
First of all, how did you make the battery symbol? Normally the long terminals are the + connections and the short ones are -. Using Proteus ISIS the current is constant. Have a look. Might be MultiSim has a better supply and simulates the depleting battery as well.
| | #8 |
Oops, nervous finger. Hint: For currents below 10mA use the LM317L. Its minimum current is 1mA, but might go down to 500ľA. The LM317 requires a minimum current of 10mA. Everything below won't be stable.
__________________ Proper Planning Prevents Piss Poor Performance Last edited by Boncuk; 30th October 2008 at 09:35 PM. | |
| | #9 |
I suspect that the problem is that the drop-out voltage is too high for his application. The LM317 has a drop-out voltage from anywhere between 1.5V to 2.5V depending on the current and temperature, then you have to add on 1.25V for the voltage referance which gives 2.75V to 3.75V. This means that if he's doing something like powering a blue LED from a 6V supply then it won't work.
| | #10 |
hi guys, in fact i should have thought twice before actually posting... first of all: i didnt create the circuit i linked to - i just linked to the resource i used. second: you are right: i tried to build a perpetuum mobile :-) that is, the consuming power was higher than it actually could be (load was much too high in order to drive my desired current through the it) thanks for all your help kermit | |
| constant current, lm317 |
| sink, source current and drive current | ervinzhou | General Electronics Chat | 0 | 4th October 2008 01:52 PM |
| Generation n Divsn of Const. Current Source | naveensmk | Electronic Projects Design/Ideas/Reviews | 0 | 12th June 2007 06:29 AM |
| Current Source vs Current Sink? | dknguyen | General Electronics Chat | 11 | 14th September 2006 11:26 PM |
| Current Source and current mirrror | lord loh. | General Electronics Chat | 12 | 25th April 2006 09:52 AM |
| Req: simple low drop constant current source | Dominique | General Electronics Chat | 10 | 9th February 2006 03:20 PM |
