Can anyone out there recommend a Laser Printer for toner transfer PCB creation? I have a budget of about $100 - $150. Also if anyone knows a good spot to buy cheap (not crappy) Blank PCBs i would love the info...
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics | |
| | #2 | |
The printer I use is an HP1020 I picked up on sale for $100 a few years ago. One could do better but at what price I am unsure. It works well at 10 mil. I have not tried smaller but would not bet on it without testing. Once you go below 10 mil there are other factors. If you are going the pulsar route email or call them for advice on the printer. Then let us know. ![]() 3v0
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | ||
I'm using the 'FUJI XEROX Docuprint 203A' at 1,200pixels resolution without complaints. I paid 2,800 Thai Baht equalling 84US$. Hans
I have been doing some reading. Most B/W lasers on the market are 600 DPI. My HP1020 normaly operates in that mode. It has a fastRes 1200 mode that plays a trick when printing across the page. It prints 600dpi sized dots but places them on 1200dpi centers. Not too useful with a 4 sided chip. HP has what they call proRes 1200. The only proRes printer pricewatch shows is the HP LASERJET 4250DTN for $1700. The discontinued LaserJet 1300 can be had for about $100 (amazon.com) and the HP toner is about $80. That could be an option as a printer dedicated to PCB printing. The FUJI XEROX Docuprint 203A does not seem to be popular in the US. It does not look like it is a full 1200x1200dpi printer. I found Max resolution (b&w) 2400 x 600 dpi. I am not sure what tricks if any it is using but like the HP1020 600dpi down the page is the weak link. I took a quick look at color laser printer too. It seems that going above 600 DPI down the page is an expensive thing to do. It may be the case that I start sending boards out when I need this kind of resolution but it is work looking at.
Hi, i just browsed your post, i suggest you visit here-http://www.pcb-assembly.com.tw, here many professional electronics engineers could help you to deal with this thing.
__________________ The leading manufacturer of powder blender, ribbon mixer, pulverizer, hammer mill, grinding mill, spice grinder, sugar grinder Last edited by lqyromeo; 28th October 2008 at 09:10 AM. | |
| | #6 |
Hi Have used a Brother HL2030 for several years with good results on most materials, glossy magazine pages, tracing paper, Laserstar film, the 'blue' type films etc. Think in the US its now been superseded by the HL2040 but thats still in your price bracket. If you are putting very small pieces of film through its better to tape them to an A4 sheet of paper, but use Transparency Tape as it withstands the high fuser temperatures than standard sticky tape. | |
| | #7 | |
I have been using 3M brand blue painters tape and it works well in both the laser printer and laminator. It is a bit less tacky then the laser printer labels I used in the past. It looked like the brother brother HL Series HL-5240 Personal Monochrome Laser Printer would be a good one at 1200x1200 for $180 but reviews of this sort are a show stopper for toner transfer. Quote:
3v0
| | #8 |
Wow thanks for the tips. I like the 3M Blue Tape. I dont know why but i think its the paper feeling to it ![]() As for the printer you think this will do? "Samsung ML2510 Monochrome Laser Printer, Up To 1200 x 600 dpi, Up To 25 ppm" Samsung ML2510 Monochrome Laser Printer, Up To 1200 x 600 dpi, Up To 25 ppm ML-2510 at TigerDirect.com Only $100 also i hear things about drums? Not sure what they are but for the toner and drum together is $80. So for about $200 i can get the printer and extra Toner+Drum.
| | #9 |
Hi, Those little Samsung printers are about the cheapest on the market over here, last time I looked at them, a new printer with new toner/drum cartridge was cheaper than a replacememt cartridge ! The 2510 has the toner cartridge and imaging drum drum in one unit. Some other makes, like the Brothers, use separate drum and toner units, which are individually cheaper than a combine unit. You can usually expect to use them on a ratio of 2/3 toners to 1 drum. Rather than buy new toner cartridges you can buy simple toner refills from many online suppliers for a fraction of the cost of a cartridge. Just one point if you are tight on space, some of the printers do have to have the fronts open and extended to hold the paper, whereas others hold the paper fully within the case. | |
| | #10 | |
HP makes reliable printers that have a solid paper feed mechanism that seldom if ever jam. With P-N-P paper I have done test with 6mil lines that were ok most of the time but 10mil are always excellent. Last edited by Rolf; 29th October 2008 at 11:10 PM. | ||
| | #11 | |
i'm saying this for the guys that might want to use it to print transparencies for photo sensitive boards. though is the cheapest b&w laser printer i know!! only 60 Euro Last edited by whiz115; 29th October 2008 at 11:09 PM. | ||
| | #12 |
Is a 1200dpi printer better than 600dpi for PCBs? I start to have problems when the line widths get to .01". On commercial made boards I do not go below .007". I don’t think 600 or 1200 is a big problem. Left to right my printer is very good. Top to bottom most printers are not very accurate. I just want lots of ink. | |
| | #13 | |
I am not looking for a printer right now but the thread was enough to cause me to start looking. Most printers are better across the page then down. For the purposes of board layout a printer is really only as good as what it can do in the worst direction. You may be able to get a bit better result by running the bulk of the traces perpendicular to the best direction. If that makes any sense. A printer that is true 1200x1200 should provide twice the resolution. It sounds like they use a finer grained toner so cheap refills with larger particles may not work as well. The quality of the toner makes a difference too. Some refilled cartridges have a lower percent of plastic, the stuff that melts/fuses, and do not work as well. The quanity of toner the printer can apply to the paper makes a difference. Some can not print dark enough. Pulsar and P&P help with this by covering the toner to prevent pin holes. The other thing that I ran into was the paper path. If a printer has a path with a tight radius it may jam more easily.
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 30th October 2008 at 12:39 AM. | ||
| | #14 |
I only have access to a 600x600dpi cannon, got it for £25 off ebay with a new toner cartridge. As for results? The toner seems fine with most papers (glossy, magazine, blue p'n'p, even managed a few boards with cheap plain stock paper) but the '600 dpi' has posed a problem for 0.5mm pitch IC's. I have no idea if 1200DPI really would be twice as good, as I printed off a design on a friends printer (1200x1200) and it was still a bit iffy. One thing I have noticed about my cheap printer is accuracy. I spent a long time trying to work out why its scaling was slightly off. For a pin header, 2x20 (40 way) it printed out slightly smaller, so by the 30th pad, the hole 'should' have been where the pad ring was. Any board smaller than 2" square, was within tolerance. Turns out this was nothing to do with software scaling (turned all that off) but was merely the accuracy of the printer at the edges of the paper (!!). Printing off a design in the center, portrait, it came out spot on. So beware people, always print off a test pattern with a grid just to see whats going on and if your printer has any weak points with accuracy. I cannot say this is the case for most cheap printers but I have never seen this mentioned before.. maybe I got a lemon eh? Other than than, 8mil track/spacing is doable, especially with blue p'n'p. As for board material, I assume you mean FR4? theres also FR2, and CEM1/3 which are much kinder to your tooling. All of which can be had off ebay. (from shops, not second hand lol). Blueteeth
__________________ Inconsistency is the key to flexibility! | |
| | #15 |
A single example of one 1200x1200 printer not working too great is just one sample.
| laser, pcb, printer |
| Sending Pic Data to a serial printer (receipt printer) | 1Steveo | Micro Controllers | 3 | 27th October 2009 11:45 AM |
| How to get flat sheets throug a laser printer? | deweyusa | Electronic Projects Design/Ideas/Reviews | 4 | 2nd May 2008 04:00 AM |
| Printer problem | Boncuk | General Electronics Chat | 4 | 10th January 2008 01:20 AM |
| Recommend a Laser Printer ? | tunedwolf | General Electronics Chat | 15 | 28th November 2006 12:48 PM |
| any information about LCD from old HP laser printer | Joseph Papier | Datasheet/Parts Requests | 9 | 31st May 2005 09:10 AM |
