| Hi, I am looking to build a 3 phase inverter to control an induction motor. What would be the best way to go about this? I am looking to control the inverter bridge through a microcontroller with a DC source variac to feed the inverter. I know there are a few ways of doing it, but which is the best route to go down? | |
| If you get something like:- EUROTHERM DRIVES|650-011-230|INVERTER, 1 PHASE, 1.1KW | Farnell UK That does the whole lot for you. If you want to control the motor differently, buy one and just use the power electronics from it. They have a bridge rectifier, and 6 transistors to make the variable 3 phase. Some have a regulator to change the DC voltage. | |
| Any advice guys? | |
| How big is the motor you need to drive? If it is small, you might be able to use one of these: http://www.fairchildsemi.com/ds/FS%2FFSBB20CH60C.pdf I think this module is capable of 2kw at 220VAC You may even be able to get some free samples. Fairchild Semiconductor - Site Search - Motion - SPM(TM)
__________________ Jeff To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be. | |
| Very small motor, about 50watt at about 40VAC. This may work then, thanks. | |
| Ok guys, I have a DC source variac to supply the inverter circuitry. However, this DC souce must be altered in accordance with the frequency to maintain the air flux gap, therefore I am going to build a DC-DC buck boost converter to control the DC voltage into the inverter. The inverter will then switch this DC voltage to generate a six step square wave across the 3 phase induction motor. Can anyone see any problems with doing this? | |
| difference between cmos inverter and bicmos inverter | tipu87 | General Electronics Chat | 2 | 9th October 2008 09:56 AM |
| Phase Sequence or Phase Present | neelam29 | General Electronics Chat | 7 | 23rd May 2007 11:25 AM |
| Phase shift - Phase Angle | windozeuser | General Electronics Chat | 19 | 7th December 2006 11:09 PM |
| Three Phase Versus Single Phase For EV | fzn10 | General Electronics Chat | 4 | 31st July 2006 09:39 AM |
| converting 3 phase motor to single phase | norberto fines | Electronic Projects Design/Ideas/Reviews | 6 | 2nd September 2003 11:21 PM |
