Tools | Display Modes |
#1 (permalink) |
I'm new to the electronics world and am trying to find out if there is a general rule of thumb for relating resistor values to steps in a keyboard... i.e. if there is something like 100 ohms between c and c#. help please! All i'm using is a simple 40106 oscillator.
#2 (permalink) |
If piano keyboard frequencies are equally spaced on a logarithmic scale, then yes.
But the 100 ohms would increase by some constant factor, not stay at an absolute value of 100. The factor is what stays constant. Equal temperament - Wikipedia, the free encyclopedia Last edited by Willbe; 22nd October 2008 at 02:51 PM. |
#4 (permalink) | |
I don't know diddly about music, but. . . A above middle C is 440 Hz and middle C is 261.63 Hz so your resistor values for A would be 440Ω and for C, 261.63 Ω, or some multiple of that, e.g., 4400 Ω and 2616.3Ω. Absolute freq. accuracy isn't necessary unless you are going to accompany other instruments. You may be able to find 1% resistor values that match these values closely. The question is, how close do you need for an untrained ear? 1%? 0.1%? Better than that? This gets into physiology. An upper limit on accuracy would be for the difference to be indistinguishable by an experienced conductor. This application is ideal for a spreadsheet. You want to map as many frequencies to as many 1% resistor values as possible, without having to pad resistors. A better way is to make dividers that follow this 12th root of 2 sequence and use one master clock. Popera, anyone. . .? YouTube - Hayley Westenra - O Mio Babbino Caro Last edited by Willbe; 22nd October 2008 at 06:54 PM. |
| Resistor Values | MrDEB | Electronic Projects Design/Ideas/Reviews | 5 | 21st May 2008 02:49 AM |
| resistor values | toolazy2p | General Electronics Chat | 14 | 13th August 2006 10:50 AM |
| RGB LED Resistor Values? | Mike, K8LH | Micro Controllers | 8 | 6th November 2005 03:00 AM |
| Resistor values...... | madmikejt12 | General Electronics Chat | 12 | 11th October 2005 03:12 PM |
| most common resistor values | bogdanfirst | Datasheet/Parts Requests | 5 | 11th July 2003 09:36 PM |
