Old 16th October 2008, 07:37 PM   #1
Default will this circuit work?
This is another transmission project Im working on. The computer on the schematic normally operates a solenoid by applying a ground. This project however requires a different solenoid to operate. The original solenoid is about 22 ohms and the new one is only about 5 ohms. Ive replaced the original solenoid with a 25 ohm, 10 watt resistor so the computer will "see" the correct value and not throw a code. I kind of figured out that the paralleling of the 25 ohm resistor and the 220 ohm one work out to be about 22.44 ohms which the computer will accept as "good." This would also allow Q7 to operate the new solenoid for the project. Will this circuit operate reliably or at all? Thanks
P.S. The arrow next to the computer is where I would splice the project in at
strokedmaro is offline
Old 16th October 2008, 08:31 PM   #2
As written, no, this doesn't work. If you showed the other connection to the solenoid, it might.
This is unlikely to work because the new solenoid needs enough current to operate. It draws 2.4A at 12V but with the resistor, it will see 400mA. The old one only needed 540 mA and your circuit was probably sized to deliver that current. While your circuit won't "throw a code" (what ever that means), you won't be able to deliver enough current to the solenoid (technically, draw enough current from) so get rid of the resistor. Then, you should look at the transistor specs and see if it can handle the current (Ic). If not, you will need to upsize the transistor and make sure that it's getting enough base current times its Hfe to satisfy the new solenoid's requirement. I'd try to find a closer match on the solenoid.
Last edited by philba; 16th October 2008 at 08:35 PM. Reason: fixed calculation error
philba is offline
Old 16th October 2008, 08:41 PM   #3
I forgot the other connection but its in this updated schematic. Would it work now? Also, when I said "throw a code" it means the computer setting off a red flag for the solenoid being "out of limits" and turning on the check engine light. (caused by whatever code that solenoid would generate) I know I would have to find about a transistor for Q7 that would be able to handle at least 5 amps but just want to check the circuit for operation first. THANKS!
Old 17th October 2008, 12:04 AM   #4
You circuit has the new solenoid off when the switch is grounded (old solenoid on). Is that what you want? If not then you could replace the NPN with a PNP, reverse the diodes, and reverse the power and ground to the circuit to invert the operation.
Carl
Curmudgeon Elektroniker
crutschow is offline
Old 17th October 2008, 12:38 AM   #5
Diodes D11-13 will not allow any DC to pass. And D14 will not allow Vcc to the collector??? Am I seeing this right?
Pay it forward.
Mikebits is online now
Old 17th October 2008, 12:48 AM   #6
Transistors need a base current that is 1/10th the collector current to saturate.
Your transistor has a base current of only 45mA and a collector current of 2.4A.
It needs a base current of 240mA to saturate and turn on the new solenoid properly.
So the 220 ohm resistor should be 39 ohms/4W and the 25 ohm resistor should be 20 ohms/10W.
audioguru is offline
Old 17th October 2008, 01:01 AM   #7
When the switch is grounded, the current from resistor R14 goes through D11 and turns off the transistor.
D12 and D13 provide a bias so that the transistor is reliabily turned off when the switch is grounded. D12 and D13 conduct the current from R14 when the switch is open to turn the transistor on.
D14 is the protection diode across the solenoid to suppress the inductive spike.
Carl
Old 17th October 2008, 01:07 AM   #8
Here's the issue - your transistor needs to be able to pull 2.4A as that's what the solenoid draws. You will need to determine what your transistor can handle but it will need to be a power transistor. Power transistors generally have low Hfe so you will need to provide pretty significant base current (Ib). The TIP41 is a good example to look at. It has an Hfe range of 15 to 75. Plan on a lower number, let's say 20. To get an Ic of 2.4A, you will need a base current of 2.4/20 or 120 mA. I would put a 12/.12 or 100 ohm maximum resistor in series with the base. You could go as low as what AG says. Put the transistor on a sizable heat sink as the Vcesat is 1.5V which means you will generate 1.5*2.4 or 3.6W. Don't be touching it...
However, I'd look into using an N Channel MOSFET. They are much better suited to power control. One with a low Rds will generate MUCH less heat. One that should work ok is the FDP3682. It has an Rds of around .04Ω which means a voltage drop of .04*2.4 or about .1V and power dissipation of .1 * 2.4 or a bit under .24W. You probably won't need a heat sink. But, I'm far from an expert on this.
philba is offline
Old 17th October 2008, 01:21 AM   #9
No, no and no.
hfe is the AC current gain. hFE is the DC current gain when the transistor is not saturated and has 4V or more from collector to emitter.
You want the transistor to saturate so the base current must be 1/10th the collector current as is shown in the datasheet.
Old 17th October 2008, 02:25 AM   #10
Ok, duh on my part. I did not notice the relay. And D12-13 get current from Vcc which I ignored. What the heck was I thinking?
Pay it forward.
Old 17th October 2008, 04:25 AM   #11
Originally Posted by audioguru View Post
No, no and no.
From this TIP41B datasheet
On page 2 hFE is listed as DC current gain. Yes, I used the "incorrect" symbol but what I said is still correct for DC current gain. For the TIP41 hFE - DC Current gain ranges from a low of 15 to a high of 75. Using 20 is fine. To be ultra conservative, use 15 or provide a higher base current. In general all you need to do is provide enough base current to get Ic to 2.4A.
But like I said, a MOSFET is a far better design. You don't have to spend the money on a big heat sink.
philba is offline
Old 17th October 2008, 05:17 AM   #12
Look again. Its hFE is listed when its collector to emitter voltage is 4.0V or higher. The transistor is far from saturation but the current is what you want. The transistor is heating a lot and the load has a low voltage and might not work.
Buy a bucket full and test them all. A few will do what you say.
I design circuits so that all passing transistors will work properly.
Old 17th October 2008, 05:38 AM   #13
Ag, may be a lot of things, but one thing I have learned is that he is usually not wrong. I would bank on it
Pay it forward.
Old 17th October 2008, 09:09 AM   #14
Thanks for breaking that down for me...makes it a lot easier. So if I have a solenoid (or lamp or whatever) that only draws 1amp I could use the same transistor/ change the resistor to allow 100mA and that would be saturated? Im guessing the closer to the transistors current limit the hotter it gets? Disapates more heat? So the example above would run cooler that on the 2.4 amp load? THANKS!!
Old 17th October 2008, 09:12 AM   #15
Your right...I didnt notice that mistake. I will draw up a new schematic when I have time...or maybe someone could modify mine. I will have to play this weekend
circuit, work
CIRCUIT DOESN'T WORK Russlk General Electronics Chat 14 25th November 2008 05:34 PM
Why does this circuit even work? electronzen General Electronics Chat 2 28th September 2008 06:44 PM
Will this circuit work? b_reagle Electronic Projects Design/Ideas/Reviews 36 8th August 2008 08:24 PM
Will this circuit work? beluluk Electronic Projects Design/Ideas/Reviews 5 23rd July 2006 05:31 AM
Would this circuit work? CoTang Electronic Projects Design/Ideas/Reviews 10 8th April 2004 02:04 PM
