Old 22nd April 2004, 08:02 AM   (permalink)
Default Help.............Infra-Red Transmission
Hi everyone,
I have a problem here. I am currently working on a project. It requires me to transmit data from one end to the other using Infra-Red. I've got a 38kHz signal generated using a 555 timer, an IR diode and a receiving module IS1U60. From what i understand, the IS1U60 should allow me to get a High output when theres no signal received and a Low signal where theres a 38kHz waveform. I tried to transmit the 38kHz over to the receiving module but fail to get the desired output as stated. Please help me......its urgent. Thanks
alvin_lee is offline   Reply With Quote
Old 22nd April 2004, 07:34 PM   (permalink)
Default Re: Help.............Infra-Red Transmission
Originally Posted by alvin_lee
Hi everyone,
If it doesn't work you must be doing something wrong, IR receiver IC's are very easy to connect and use - are you sure the 555 is at about the right frequency?. You could also check that you have IR coming out the IR diode, use a camcorder, webcam or digital camera to check it (IR shows up white).
