homemade double sided pcb's suffer the scenario of sodering when it comes to dealing with tight areas... samples of these tight areas are dip socket pins and various connectors (db connectors in particular) is there a good way of soldering the top part of such components? in the case of a db connector, the soldering iron tip is too big to fit between the terminals attached to the pcb, thereby soldering cannot be made properly on top. hot air soldering can reach tight areas, however there are risks melting the plastic casing of such components... | *Component obscuring top layer |___________ ==|==|==|== A -> how can this layer be soldered? ==|==|==|== B -> can be soldered easily \------ Pins------/ If A is obscured because of the physical construction of the component, then soldering the top layer would be quite a headache... B won't have problems since its the bottom and everthing is "clear" on that layer. is there a way of soldering the top part of the pcb for the tight areas mentioned - particularly, w/o using vias for the attachement? |
I'm not sure i'm quite following your diagram, but basically that's part of the design process. You make sure that it is in fact possible to solder all components on the board.
Use SMD components...
I didn't want to use them at first, and now... now i hate it whan i have to use a normal trough-hole device :lol: Normal SMD-IC's (SO) are easy to hand solder with some practice (i even have some QSOP's hand soldered!) and you can always reach the legs. Save's you a lot of that damn drilling too. |
(permalink) | ||
however, there are some components that are not surface mount - like the dsub connectors... Quote:
Home-made PCBs without plated-thru connections should have artwork made with this problem considered. That is, avoid connections to the component side solder pads underneath an IC socket.
One other solution is to pre-solder a thin wire through the hole to connect the top pad to the bottom, before the IC socket is inserted.
"Having to do with Motion Control" |
(permalink) | ||
