Does anyone here has a schematic for digital ammeter. Thanks in advance. | |
Use a digital panel meter with a switch to connect the various shunts for each range
ljcox, tnx for a quick response. But what i need is an auto range one, it will be used to monitor the charging current in a battery charger ckt.
| | #4 | |
If you don't need that large a charging current, scaling to 1.999A would give 1mA resolution in 2A. | ||
Thanks, Nigel... By the way, Do you have a simple/cheap ckt of a digital meter that I can build? | |
| | #6 | |
| | #7 | |
A common replacement for the ICL7107 and ICL7106 are the NJU9202 and the NJU9201 respectively. Digikey sells these IC's for around $6, which provides some cost reduction. Still, most panel meters are around $12-$15. So this option is definately worth taking a look at. Here's a link to a recent topic about ammeters which should give you some good hints, if you should decide on going the ICL710X route. http://www.electro-tech-online.com/v...111&highlight= | ||
| | #8 |
Thanks a lot guys! Such a great help... God bless! | |
| | #9 |
i think this is what ur looking for mate i used this in my degree switch mode power suppy project it measures up to 5 amps in 10mA steps R1=39k, R2=47ohm, R3=13k, R4=220ohm, R5=1.5k, R6=1M, R7=100k, R8=3.3k, R9=15ohm, R10=56ohm, R11=100ohm, RS=0.1ohm 3watt. R1= 1k trimmer, D1=1n4148, D2=1n914, C1,4,9=47nf, C2=220nf, C5=10nf, C6=100nf, C7=100pf, C8=680pf, C3=100uf 16V electr, C10=10uf 16V electro, Q1=2sc945, U1=ICL7107, U2=LM7805 5V regulator This runs 4 '7 seg displays' | |
| | #10 |
.. :lol: :lol: a couple of days more and it will be exactly 2 years :!: :lol: Thanks anyway, may be useful to someone else1 | |
| | #11 |
Design Calculation of a digital ammetre, Type of digital ammetres, Literature Review and theoritical background
| | #12 |
can any1 help me on this topic??? 3switches will have an output of 1, 2 ,and 3 in seven segment.. 1rst switch has an output of one.. 2nd is two.. 3rd is three.. then it will give an output on dual seven segment incrementing from 0-99 plzzz.. nid schematic diagram.. thnx.. | |
| | #13 |
ronnel, You should start a new thread rather than hijacking this one... Etiquette....
__________________ Eccentric millionaire financed by 'er indoors | |
| ammeter, digital, project |
