Old 14th March 2003, 07:38 PM   (permalink)
Default 3 Channel LED circiut ideas please
:? Hi everyone, I am looking for ideas or help for a project to wire up some RGB LED's I need to create a 3-channel circuit that continuously and randomly varies the voltage on each channel up and down (smoothly) from 0 to 5 VDC fed from a 12VDC supply. If anyone has any thoughts they would be most welcome.
Cheers all
J M West
jmwest is offline
Old 14th March 2003, 08:11 PM   (permalink)
so you mean that you wanna use random voltages for each channel so you can get lots of colours randomly?
why random?
maybe better if you can use a potentiometer to vary the voltage for each channel and produce the light colour you want.
bogdanfirst is offline
Old 15th March 2003, 08:21 AM   (permalink)
I am planning to use this as a method of getting a custom motorbike fuel tank to randomly change colour at night, I can cover the tank OK and have tried this with single colour LED's, using a manual method of changing colour would have me trying to ride the bike and pick a nice colour at the same time - not very safe.
Cheers
J M West
jmwest is offline
Old 16th March 2003, 05:54 PM   (permalink)
i build a cricuit that does what you want. It consists of 3 triangle oscillators running freele at different frequencies. The effect is a slowly changing color pattern.
Just have a look at my website - it's in german, but the picutres speek for themselves .
http://www.quantensingularitaet.com/...all/color.html
DoS
dos6510 is offline
Old 16th March 2003, 06:48 PM   (permalink)
o, i like your idea very much!!!
but maybe you can explain in english how the circuit works, and about the other thing that you heve build.....the cuant beam rezonator(Quantenresonanzbeamer-did i get the translation right?)
what is it really?
Old 17th March 2003, 05:39 AM   (permalink)
the circuit is pretty simple. Just build a triangle oscillator (1/2 LM324) for each color channel. I stole the schematics for that anywhere on the net ;-)
Build three of them using different time constants (== Cs) for each channel.
The output transistor works as a current amplifier.
I wanted to have two changing lights, but was to lazy to build the circuit twice. So I put two leds with different color in series for each channel. This results in two rgb lights changing color with different "phase".
When i have time, iŽll translate that page of mine.
The other "project" - the name is just for fun. Is just the way i light my living room ;-)
DoS
dos6510 is offline
Old 17th March 2003, 10:15 AM   (permalink)
ok, i got the idea about the seond project...
il looks quite strange, "alienish"..
Old 17th March 2003, 04:37 PM   (permalink)
yes it looks strange - but it was meant that way. As you can see there are two light "modes". One uses two compact flouresecent lights to illuminate the ceiling.
The other one uses a "down spot" and in addition to it illuminates those funny red cylinders (done by leds)...
DoS
dos6510 is offline
Old 17th March 2003, 07:43 PM   (permalink)
what did you put in the cilinders....?
Old 18th March 2003, 12:21 PM   (permalink)
@bogdanfirst:
They are made from red acrylic glass and are illuminated by high efficient red leds.
But this is only looking great if the "main" illumination (via ceiling) is off.
DoS
dos6510 is offline
Old 18th March 2003, 01:47 PM   (permalink)
i can imagine. where did you get that from?
Old 19th March 2003, 04:01 PM   (permalink)
Those things are sold at IKEA. They are use at the end of the curtain rails as a closing end. That's as well the source for the "Color Balls".
DoS
dos6510 is offline
