| Hi can anyone help me with the circuit diagram & components to build a 12 volt to 240 volt invertor that i may simply plug into a car cigarette lighter. Many thanks Mark | |
NOTE: i tried this last night, and the capacitor exploded, so be warnedyou may need to change a few things | |
But it's a pretty poor design anyway!, I would also add diodes from the base of the transistors to the emitters to prevent the transistors failing (cathode to base, anode to emitter). | ||
| i did put the caps the right way round... it still blew for some reason... and what would you say was a better inverter schematic? | |
There are a number of inverter circuits on the net, mostly much more complicated than this one - for good reason. This one is really an example of how NOT to do it 8) | ||
| | (permalink) | ||
So as shown the capacitors are reverse polarised by around 11.3V, result - BOOM!! - well, at least a quiet hiss!. Also, without any catching diodes, even with the capacitors the correct way, it's likely to blow the transistors - as one transistor turns on it drives the base of the other around 11V negative, much too high for a 2N3055. | |||
| ill have a look for a better inverter... prob safer aswell | |
| Hi mhutsby, Hi andrew, This inverter circuit has cropped up a good few times. Every time i see it, i cringe. I consider it to be a poor circuit, however, i have not constructed it. Although i have constructed other low power inverters most of which have worked adequately. Here is a link to the thread on this forum where i first saw this particular circuit: http://www.electro-tech-online.com/viewtopic.php?t=2695 I too thought the capacitors were the wrong way round, but this is not the opinion of others who have examined this circuit. One point which was made clear is that the high ripple current demanded of the capacitors in this configuration means they have to be tantalum types. (or equiv) Cheaper electrolytics will not stand the heavy demand and will fail. That earlier thread has many useful comments from other constructors too. One basic point is to check that the two 12volt windings are correctly oriented. Normally i don't reply to a post where the original poster has only posted once. There are too many that never post again. Little home made inverter units are a favourite of mine, i've made quite a few. I favour the bridge type circuit with four Tr's or Ft's which i originally started using because it has a single winding as primary. Best of luck finding a nice simple inverter Andrew, Regards, John | |
| any one have rectifier circuit with thyristor ? I need it for my hobbies | |
| | (permalink) | ||
| Hi Nigel, Please have a look through that earlier thread about the same circuit, and the thoughts of others who have looked at it. That earlier thread has a colourful diagram with all the component values included. This poster did not mention that he was using 3055's but you are correct, those are the ones that this is supposed to use. http://www.electro-tech-online.com/viewtopic.php?t=2695 I would be very interested in your comments on what others have said about it. Regards, John | |
As I see it, the positive side of the capacitors should go to the collectors, otherwise they are reverse polarised by 11.3V or so, and (as has happened) the capacitors will vent. As also mentioned, I agree that the diodes and resistors are to absorb the back emf from the transformer - probably the only part of the circuit which isn't completely horrible :lol: | ||
| Hi Nigel, yes you are right, this earlier circuit and description from Tony Van Roon clearly stipulates non polarised tantalum caps http://www.uoguelph.ca/~antoon/circ/...e/inverter.htm Regards, John yes that is me too, i was away at another machine, and got no cookie. I couldn't remember my password, so i just registered again. Later realised i could have asked for my password ! | |
