Old 12th April 2004, 03:49 PM   (permalink)
Default HELP!! : transistor switching circuit
harlow there, if i have a voltage range from 0.6 volts to 1.4 volts, can i use transistor to switch on a typical LED which has the forward voltage at round 2 volts?
If cannot, how can i do that?
Thanks in advance :wink:
Desmond.
desmond is offline
Old 12th April 2004, 05:20 PM   (permalink)
Are you saying you have an input voltage of 0.6V to 1.4V? Is there a supply that you can use too?
fat-tony is offline
Old 13th April 2004, 12:24 AM   (permalink)
the supply i used actually is 5 volt, but due to a circuit there, the output i have is 0.6volt to 1.4volt (the range) ...
then i would like to prove that the voltage there is not 0 so i am thinking to use LED as the indicator.
so do you think 0.6volt (we take the minimum) can switch on a LED by using transistor? maybe bjt or mosfet? or what should i do?
Thanks.
Desmond
Regards,
Desmond
desmond is offline
Old 13th April 2004, 01:52 AM   (permalink)
The problem is that 0.6V is just a little lower than the Vbe for most BJTs. I'll think about it a bit more and get back to you .
fat-tony is offline
Old 13th April 2004, 01:58 AM   (permalink)
If you're not adverse to using an op-amp, it would get a lot easier
fat-tony is offline
Old 13th April 2004, 08:20 PM   (permalink)
yeah .. i am thinking the same way too
i will try it out with LM751 first lar ..
thanks man ~ :wink:
Regards,
Desmond
desmond is offline
Old 13th April 2004, 09:03 PM   (permalink)
The LM331 is a component I have enjoyed lately. Maybe it would be handy for you. It comes in a convenient SOT-5 package.
j.
John Sorensen is offline
