| I'm planning to build this light following microbot: http://www.winnipegrobotics.com/Proj...an%20Robot.pdf basically it uses 4 photocells. These are fed into two comparators, the outputs fed into two 556's which then drive the motors. According to the author the 556 is used for for its comparator, flip-flop, and its ability to source or sink up to 200mA of motor current. I'm very new at this and I don't quite understand why I can't drive the motors directly from the comparator outputs. From what I understand the outputs will be either 7.5V or 0V. Enough to drive a mall hobby motor? I guess I'm not sure what s meant by "source or sink 200ma". Thanks Marc | |
| | (permalink) | ||
| Thanks Nigel. Appreciate the quick reply. So when designing these circuits, if an an IC is the source of power for a load circuit, I need to determinw how much currrent the load circuit will draw and make sure the sink/source of the IC will handle it in addition to making sure the output voltage is sufficient. Correct? Secondly- Is there an easy way to determine how much current a motor draws ? These hobby motors typically only give a supply voltage range. Thanks again, you guys are great. Marc | |
| Hello, The current taken, under load, must be less than 200mA due to the capacity fo the 556 driver. If you put in series a 1 Ohm, 1 W resistor with the motor and feed it with 9 volts, the resistor will drop: I xR= max .2Ax9V= max. 1.8V at full load. This can be checked by applying step by step a friction brake, and reading the voltage drop in the resistor. One word about the comparator: never let the unused inputs floating, tie them to ground or +V. This IC can sink only 20mA and source 40mA and are very sensitive to spikes and noise in general, so it would not be a good idea to use it as a motor driver, unless using a very good designed suppressor circuit. | |
| | (permalink) | ||
Assuming this is the case, a further question: my multimeter can handle a maximum input current of 200ma. Although the current is not likely to be this high, would it be safer to instead place a resistor in series with the motor and then measure the voltage drop across the resistor ? Thanks Marc | ||
| | (permalink) | |||
Yes, you could measure the voltage drop across a small value resistor (which is how the current ranges in your meter work anyway). | ||||
| Ron, You are completely right, sorry for the mistake. | |
