| hi, i am planning to make a low - cost diy etching tank out of a small rectagular acquarium (large enough for hobbyist size pcb's). my dad has an old 12v air pump used for car tires. i think the pressure of that would be enough to bubble the solution for the pcb. here is the setup:
the problem that i am now facing is heating the solution.
i would also place a diy temp controller depending on the heating element that will be placed. | |
| fish tank heater | |
| Halogen lightbulb. | |
| :? you have a fish tank, so as in the reply above, a fish tank heater would be the Obvious choice :? | |
| Yes, i agree a fish tank heater is what i use and remember it doesn't have to be on all the time because the solution only has to reach 50 degrees C. | |
| there are some thermostatic fish tank heaters as well, so you can just 'dial' in the required temp, then when the neon goes out - the solution is at the required temp | |
| Big glass test tube, with high wattage wire-wound resistor inside, rubber bung etc for cable out. Glass thermistor, epoxy protected, suspended in the solution to monitor temp, and control on/off power to resistor. Been threatening to build this for my self for many moons. I still end up bunging a jug in the microwave and warming it that way Note: I don't use ferric, it's not too keen on the microwave, plus I always manage to stain something Steve | |
