I need to know how to make a circuit for my car to read the voltage off my Oxygen sensor. It puts out a voltage from about 0-1 volts. I want it to be a digital numerical LED display. It really only has to display in hundreths of a volt. I would assume it needs to be of a high resistance so it doesnt "steal" some of the signal going to the cars actual computer. Also it needs to update as quick as possible, realtime if possible. This is my first project and I have basic experience so keep it simple. I know how to make one in the bar display but want a numerical display is there an IC that will hook up to a 2 digit LED?
Thanks in advance. Tim |
Super Moderator
A liquid crystal digital panel meter is available - 0 to 200mV, 3 1/2 digit display, 1000Meg input impedance, 9 to 12v supply.
A simple 2 resistor divider will give the required range. Maplin in the UK (WWW.Maplin.co.uk) sell it for £17. (order code GW01B) I bet others (Radio Shack, RadioSpares, etc) also do similar devices? :?: This device expects the power supply negative and signal negative to be the same (both 0v) :?: :!: A voltage regulator would be a wise idea to protect the meter from a car's battery voltage - this can reach 15v ! :!:
I need a memory upgrade ... My head is full ! |
| Real time freq correction problem | Rosco101 | Electronic Projects Design/Ideas/Reviews | 2 | 8th April 2005 11:02 AM |
| Interfacing real time clock | goodpickles | General Electronics Chat | 1 | 13th February 2005 09:35 AM |
| Real Time FLIR Video Feed | digital0ne | Robotics Chat | 3 | 11th April 2004 06:21 PM |
| real time clock | finst | Micro Controllers | 4 | 17th January 2004 12:11 AM |
| list of Real Time Clock | thendo | Micro Controllers | 2 | 8th November 2003 05:41 PM |
